Question about Whirlpool Refrigerators
No water to ice maker but there is to the water dispenser in the door. Whirlpool model ED22PQ
  • Whirlpool Master
  • 4,654 Answers
This could be two reasons. The water control valve that sends water to the ice maker or the ice maker is not sending the signal to the water control valve to send water to ice maker There are 2 valves on back of your refrigerator one for ice and the other is for the dispenser. If ice maker is empty then the signal should be sent to back control valve and 120 volts should open the valve for about 4 seconds. If that valve is bad nothing will happen.You can test the ice maker by filling with tap water and if it cycles until time to refill and no water fills the tray then I think the water control valves need replaced. Click on link below and enter your model number in model search feature. Let me know what you find, Sea Breeze
http://servicepartstec.blogspot.com/
Water Valve - Dual Outlet
P/N: 2188542
Posted on May 25, 2009
Ice maker not working
Ice makers have a heating element to thaw the inlet and allow water to flow into them perhaps the heater is broken and it can't get water to make ice. Check the hopper to be sure it has ice in it. If it does check it for obstructions from the hopper to the door.
Apr 04, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool model ED25PWXBN00 refrig and the ice maker is making ice but the part that holds and dispenses the ice has broken and no longer dispenses ice. what part do i need?
That depends if the ice maker continues to fill with water or just sits there with the ice slots empty. Sometimes it is the dual water control valve=> 4318046 Water Control Valve
and sometimes the ice maker itself. Does not hurt to have an extra part of each if you are a ice user like myself. If ice slots are empty fill with tap water and allow to freeze. If the ice drops and slots do not refill with water then replace the dual water control valve. 4317943 Ice Maker Assembly.
Oct 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
It's not making ice. Not sending water to the ice maker. I replaced the filter this morning. Water is dispensed for drinking , but not for the ice maker.
I just replaced the water valve because my water dispenser in the door kept dripping. Google parts for your model and put in water valve. It will cost around $80 for the part. My sic year old did most of thr reacement after watching an online video.
Aug 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Nov 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
346 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
