reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
This is not a problem specific to flat panel televisions. In fact, it's not a problem at all. The documentation that came with your TV remote will have instructions on where to get the code and how to program it into the remote. Basically, you'll need to refer to the documentation of the device you want to control with the remote. It should list the code for that device. Then use the documentation for the remote for instructions on adding the code.
Your right that remote does not have the codes supporting that model but personally I would try the following codes of 055, 026, 012, 013, 003 (based on Samsung ) as originated may be the closest you will find to this. Other than that your all in 1 is no good unfortunately.
Google the model number of remote and the set for "manual" which should have possible codes.
With the manual for the remote look to see if it has a search mode which will allow you to try every possible code one at a time to find one that works.
Universals even if programmed will be missing key features the original remote had.
Hi, You need a code to match with your TV remote.
The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
