Question about Canon PowerShot SD1100 IS Digital Camera
USB trouble with SD1100is
I connect the usb to the camera after it's plugged into the computer, however nothing is happening. I went to the device manager to scan the drives for my device but my computer reported:
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
What does this mean? Is it fixable? What can I do?
  • 108 Answers
Code 19 Your registry may be bad. (Code 19) To check your registry, click Check Registry. If the registry is bad, Windows will restart your system and go back to a previous registry that is good. Solution button: Check Registry This code means that the registry returned an unknown result. To resolve this issue, follow the recommended solution, which will run Scanreg.exe. If this does not resolve the issue, type "scanreg /restore" (without quotation marks) from a command prompt. Finally, remove the device from Device Manager, and then redetect it using the Add New Hardware tool in Control Panel. Hope this help's ;)
Posted on May 25, 2009
Why won't mu usb cord work for downloading pictures
Here is one possible solution. Some devices require that you use the USB cable that came with the device. Other USB cords won't work. This happened on a Nexus tablet I bought recently. When I tried to charge it with another USB cord, nothing happened. I had to use the exact USB cord that came with the tablet, even though both cords looked identical.
Aug 14, 2014 | Cameras
Kid Tough Digital camera is not being recognized on my computer
The camera should not need software to connect to the computer. It should be "Plug & Play". Try plugging the camera into a different USB port (look on the back of the computer). The software is only needed to customize the pictures. Ensure the camera is turned on after plugging in the USB cable. If no result, open the Control Panel and look at the Scanners and Camera settings.
If you know how to view the devices using Device Manager, open it and look for any yellow highlighted icons. If you have any highlighted icons, then that is where the trouble lies.
Jan 02, 2014 | Fisher-Price Kid Tough Digital Camera
My computer no longer recognizes my nikon coolpix L5.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 19, 2012 | Nikon COOLPIX L5 Digital Camera
Trouble uploading photos from my camera.
You may not have the software installed on your computer or it's not installed properly.
First tru plugging in your camera using the USB and turning the camera on (press the arrow buttun for about a second). The FinePixViiewer should open.
Apr 30, 2009 | Fuji Finepix Z20fd Digital Camera
Nikon coolpix s210 will not connect to mac
I have a Intel Mac Powerbook running OS10.5.8
On a coolpix 100, the default setting is that the camera is charged by the computer through the USB cable. You need switch that OFF.
While the camera still does not show as usb device, you can access it through the Nikon transfer program AND through iPhoto
ez-pics
Mar 19, 2009 | Nikon Coolpix S210 Digital Camera
When I plug in the M407 camera nothing happens
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 15, 2009 | HP Photosmart M407 Digital Camera
Helpp! exceeded the power limits on its hub port?
try to change a new USB cord, and if it does not work the problem is a device then
Jun 21, 2008 | Vivitar MAGNACAM Binocular
Can't get pics off the camera!
USB can be funny some times- it has worked so you know what to do OK? Check-the USB setting- Start/ControlPanel/System hardware/device manager Rund down to the USB setting and open it check for any yellow makers intcatiing afault - seek help from there. If you are using a hub or have multiple other devices connected.- disconnec them and use the USB cord direct to computer. Have you remembered to switch the camera on- it has good batteries- set to upload Huh! So much to remember easy to forget something If the trouble wont go away- go buy a card reader and leave that lugged in to usb.
May 26, 2007 | Sony Cyber-Shot DSC-P31 Digital Camera
Loading photos onto computer
Unplug all other USB devices. Restart computer then plug it in solo.
May 20, 2007 | Samsung Digimax S500 Digital Camera
Troubling uploading pictures
please chek the button on camera stand taht must be on and second camera must be in USb stream mode. all you nee dto change the setting no technical problem. also you nee dto chek for USB driver whether it is installed . if it is installed when you connect cable the computer give new device found message. r u getting that? let em knwo Thanks Sangita
Apr 23, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
185 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
