Question about Avocent Computers & Internet
The letter k can not be sent over the KVM switch. what is up with that?
  • 111 Answers
Try plugging in to one of the computers directly and bypass the KVM. I'm guessing that you'll have the same issue and determine that it's a bad keyboard and not the KVM.
Posted on May 25, 2009
Windows: USB Dongle shows up in Device Manager as Disk Drives: KVM vmDisk USB Device, and DVD/CD-ROM Drives: KVM vmDisk USB Device. Steals drive letters I need. How to get around this? have uninstalled...
Hi Bruce:
Sorry to hear that you are having problems. If you still want to use the device, you can assign drive letters to you other devices that do not disrupt the use of you KVM switch. Using device manager, you can change drive letters on all drives except your hard drive, usually drive 0.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
As for uninstalling the KVM device, if you want to completely remove all files from your computer, do a search (off the start menu) and search for *KVM vmDisk USB Device".
The delete all the files that are found in the search.
Let me know if I can assist you further or you need any clarification on my instructions.
Jan 12, 2011 | Avocent DSR2035 (DSR2035001) 32-port KVM...
I am looking for the hotkey combination for our HP 336044-b21 KVM switch from a iogear KVM?
IOGEAR KVM switches uses Scroll Lock for the hot key. The models of IOGEAR KVM switches starts the letters "GCS". I don't think that your HP 336044-b21 came from IOGEAR.
Anyway, if that's an IOGEAR KVM switch, you may quickly press Scroll Lock twice + Enter (for two port KVM).
Scroll Lock twice + port # + Enter (for 4 port, or 8 port KVM).
NOTE: You need to verify the brand of your KVM switch by referring to the user manual of it.
Thank you and good luck!
May 20, 2010 | HP 336044-B21 8-port KVM Switch
KVM switch is ghosting images on the monitor.
Dear sir good day try to disconnect all of the KVM switch and then try use one pc only and trace for the bad cable ... and if all are the same then you must go to the warranty center and ask for replacing the KVM
thank you
Dec 23, 2009 | Computers & Internet
Codes posted dont work. can i try anything else
THESE ARE FOR TW PLEASE CHECK EACH LETTER AND NUMBER ONLY 1 MAY NEED CHANGING.
00= 83 5D 12 B8 96 F6 1F C4
01= D2 F9 3F 22 0C A7 D6 C9
Oct 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Chorus have changed codes in ireland can anybody help?
sorry i left out the letter E at the end.
the proper line is 5E01 01 AA269EF2E914D1AE
no need to change the 00 line
Apr 02, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Users manual for KVM model ''MT-471s Auto KVM''
turns out if I double tap and hold the scroll lock key, the kvm rapid beeps and while in this mode, I can hit the numbers 1 to 4 to pick the port I want to connect to.
The double tap on the scroll lock suggestion was sent to me by a fixYa responder. Thanks,
Mar 19, 2009 | Computers & Internet
How do i put the codes into the eurovox ? Do I use the remote control ? as there is only numbers on the remote and no letters. Thanks
if its like the digivox the buttons for audio, pause, and the coloured buttons correspond to the letters, give them a try, hope this helps
Feb 17, 2009 | StarTech.com StarView SV211K 2-port KVM...
Codes
Key 00 = DD BE E3 62 30 D9 2F 25
Key 01 = OA D2 24 A5 A6 8O CO EE
May 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
KVM troubles
Belkin.com....Switching software update.
Dec 04, 2007 | IOGear GCS632U 2-port KVM Switch
Dakota Scout kvm
I use one of these, and hotkey sequence is . Where is A,B,C or D.
Jan 02, 2007 | Dakota Scout KVM Switch
Computers & Internet Logo
228 people viewed this question
Top Avocent Computers & Internet Experts
David Payne
David Payne
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
