Question about GE GTS22WCP Top Freezer Refrigerator
Water on shelves?
I have a GE gts22wc fridge. About once a week I notice that there is water laying on the shelves in the fresh food/bottom of the fridge. There is also more and more frost accumulating in the freezer. The freezer is at 8 degrees everytime I open the door.???
  • GE Master
  • 4,655 Answers
This is a sign that your refrigerator is not defrosting properly. I you can I want you to unplug the refrigerator and inspect the freezer behind the panel in back of freezer. If needed defrost the evaporator coils with a hair dryer. You will need to have a multi meter or Ohm meter to do some of the test. On back of refrigerator is a circuit control board that while unplugged from wall I need you to examine for burn marks or loose solder connections on back and front sides. You can see a breakdown of parts by putting model number GTS22WCMBRBB into the model search feature at the link below. Let me know what you find and when ready I want to go through some test if you find nothing wrong with the control board. click link below Thank You, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 25, 2009
Why is condensation in fridge?
Good afternoon friend, thank you for your post!
I understand that your Frigidaire refrigerator has moisture forming underneath the bottom panel of your freezer and that is causing water to drip onto your shelves. Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side of a top mount. On a side by side it can be found on the right hand side. I look forward to your response. -Matt
Jul 16, 2014 | Frigidaire Refrigerators
Problem is rotten smell inside GE profile fridge. I've checked for rotten food-none; taken everything out and cleaned inside plus all shelves with added bleach in water. Smell is still there. I...
Hi, pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. You can also mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section. Too much bleach and the smell of bleach would be circulated by the fan to the room, so be sure to add water. Finally, another popular methods of removing fridge odor include washing the entire fridge out with a vinegar and water solution, placing fresh coffee grinds or boxes of baking soda on each shelf and even using trays of cat litter.
May 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
My Whirlpool refrigerator is leaking and water is dripping on to the shelves and in the bottom of the fridge under the crispers. I had a guy from Cal Tech Services to look at it 3 times now and it still...
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Hope this helpout,
Jul 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
Water is getting into the refrigerator. there is
If the fridge has the freezer on top - the problem is in clogged drain under the evaporator.Whenever the defrost cycle is activated (every 6-12 hours), the water will drain not to the drain pan underneath the fridge, but into the air vents between the sections. Depending on the make/model to get to the drain line you may need either:
  • to remove the back cover in the freezer section;
  • remove the bottom of the freezer section;
  • remove the console with controls on the ceiling of the fresh food section
  • get behind the fridge, find the drain line going to the pan under the fridge remove the drain line and clean.
Good luck.
Vlad
First Choice Appliance
Mar 13, 2010 | Refrigerators
Water blockage
does stuff in the bottom drawer in the get frozen stuff in it? the tubing for the water is behind it. if this the case then your fresh food compartment sensor is off try setting the fridge to a warmer temp
Dec 08, 2009 | GE Refrigerators
I HAVE A GE PROFILE REFRIGERATOR TOP FREEZER, MODEL# TBX22PAYMRAA THERE IS ALWAYS WATER ON THE SHELVES AND A LOT OF WATER ON THE BOTTOM UNDER THE VEGTABLE BINS. WHAT IS CAUSING THIS AND HOW CAN I FIX IT?
Two separate problems here.
One; remove the ice maker, then remove the back panel from the freezer. The defrost drain is probably frozen . It will have to be thawed. Then run a 1/4 cup of bleach through it.
Two. Water on the shelves sometimes is caused by the frozen drain line referred above.
But can be from a poor door seal on the fresh food compartment.
Check the sides and bottom of the door seal. It may have pulled loose from the plastic liner.
If it is warped and damaged it must be replaced.
Feb 23, 2009 | GE Refrigerators
GE GTS22WCP Top Freezer Refrigerator Logo
164 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
