Question about Brother DCP 115C All-In-One InkJet Printer
Non printing of black
Have carried out cleaning instructions more than four times and am still unable to get black to print I have used only genuine Brother or Tesco's recommended substitute.  I have just refilled with genuine Brother cartridges.  Still no joy.   HELPLESS
  • Brother Master
  • 1,113 Answers
Head blocked damaged, no fix for heads, replacement of head is fix, too expensive if not under warranty, use only brother inks. Dealer can perforn a powerpurge or you can hunt for code on web but it don't ussally fix
Posted on Oct 21, 2007
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
Replaced both print cartridges but print is faded blue
Solution: There are a number of steps you can take to solve this problem (in order of easiest & least expensive first).
1. Make sure you have tried printing a nozzle check and you've carried out all the maintenance tasks that the manual alows (align print head, clean print head etc).
2. Your cartridge may be faulty. Ink cartridges that use non-genuine ink are of variable quality and you use them at your own risk. Even genuine cartridges can expire if used after the expiry date. Bad ink can clog your nozzle. It may be that you have a dried-out ink cartridge - try another one if you have one handy.
3. The print head may need cleaning. There are Canon print head cleaning kits available (use Google top right) or you could try doing this yourself - some people have had success immersing the print head (not the cartridge) in cleaning alcohol, warm water or using compressed air to gently blow through the nozzles.
Apr 30, 2010 | HP OfficeJet 7110 All-In-One Thermal...
My status monitor says that all my colour supply levels are full. But the printer won't print in colour. Only black & white. Even when I choose the "print in colour" option. This hasn't happened...
Brother Inkjet printers' printheads are very sensitive, using non-genuine ink clots the printhead. Try to clean the head by pressing the ink maintenance button. Sometimes you need to clean several times.
Dec 11, 2009 | Brother MFC-5440CN All-In-One InkJet...
Unable to print BLACK
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
    1. Press the Ink Management key.
    2. Use the up or down navigation key to select TEST PRINT.
    3. Press Set to confirm your choice.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
Cleaning the Print Head
  2. Use the up or down navigation key to select CLEANING.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
I hope it helps!!!
Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
Canon i90 not printing black ink
You may be able to save the unit by cleaning with a qtip and some Fedron. Fedron is designed to clean platens and parts in printers and typewriters (it's original use). You can do a search on the web for locations that carry Fedron. Be extremely careful around any plastic parts becasue Fedron will eat/melt most plastics.
Jun 08, 2008 | Canon PIXMA iP90 Mobile Printer
Canon i560 Printer
It sounds as though u r using non genuine inks, even if u r not u need to change the print head
Apr 13, 2008 | Office Equipment & Supplies
Printer trouble
In my expirence with ink cartridges is that they can be faulty strait out of the box both Genuine and non-genuine (a lot more of the time on the non-genuine). My advice would to go out and get yourself a set of the genuine manufactures ink and to try those. If that works take the others back to place of purchase for a refund.
You may have to run the cleaning function several times to purge any other ink out of the machine.
Feb 01, 2008 | Office Equipment & Supplies
Brother DCP 115C All-In-One InkJet Printer Logo
132 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
