Question about Logitech Harmony One Advanced Universal Remote with Color Touch Screen
How do I set the time on Sony 46" TV with the Remote
Electric went off and now when I turn on the with the Logitech Remote it prompts me to reset the time - how do I do this
    Scholar:
  • 59 Answers
The Harmony remote comes with most, if not all of the functions of your original TV remote built in to its hard and soft keys. Choose the "Devices" button to see a list of the devices controlled by your Harmony remote, then select the Television. Once you do that, your remote will show all the functions from your TV's remote.
Unfortunately, from there, you'll need to know how to change the time for your TV (I imagine there will be some sort of SETUP function on the TV). For that information, or anything else specific to a particular device, you need to reference the device's own user manual.
I hope this helps.
Posted on Jun 18, 2009
HOW DO I CHANGE MY SONY LED TV FROM ARABIC WITH ENGLISH
You would need to do a factory reset
From the Sony Forums:
factory reset to your Television.
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button.
  4. While holding the UP ARROW button, with your other hand reach around the side of the TV and press and release the POWER button on the TV set.( not the power button on the remote) it should be the top button along the side panel.
Sep 06, 2014 | Sony BRAVIA KDL46EX720 46 Inch 3D 1080p...
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Sony Bravia KDL-46S41000. The picture has been having problems for a few months now, and is getting progressively worse. Sometimes, when I first turn on the power, the audio is present, but...
I suggest that you install the following firmware update and check if that helps.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6090&mdl=KDL46S5100
If the issue persists, service may be required.
Please perform reset by following the procedure before going for service.
To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW button on the Remote Control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
Jan 30, 2011 | Sony KDL46S5100 46 in. HDTV LCD TV
The time on our Sony Bravia has slowly been getting more and more incorrect. How can we re-set it?
Hello
To reset your TV to factory settings do the folloing
Turn on the TV while holding down the "Up Arrow" button on the remote control, press the "POWER" button on the TV. [The tv will turn itsef OFF, then back ON again]. Release the "Up Arrow" button.
Warning: The reset will clear all of your customised settings including parential lock settings.
OK
Jan 29, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a logitech 890. The remote only turns the tv on and off but nothing else.
this remote has a help button to resolve setup issues. you should see a message on the screen ask ing if you need help. If not this function can be activated using the setup software. Try using the remote to watch TV. Then press the help button(be sure to have the remote pointed at the TV). The remote will attempt to fix itself. the screen will then ask if that fixed the problem-choose yes or no. Continue to follow the prompts until everything is the way you want it.
This should get everything working for you. I assume you did connect the remote to your computer and went through the setup software.
I use this remote and I love it. Just be sure when using it to give time for it to send commands to all the devices.
Nov 06, 2009 | Logitech Harmony 890 LCD Remote Control
Sony 46in projection tv
To reset this unit start with pwr off. Then on oringnal remote press the display button, the number 5 button and then volume up button and then hit the power button this will take you into the service mode menu, Press the number 8 key and then hit enter, this will set the unit back to factory specs. The set should turn off itself and then power on itself to channel 3, All user setting before this procedure are reset to factory mode..
Please leave comment THX
Nov 04, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Using Harmony 550 Remote with SONY KDF-46E2000
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device..
Apr 05, 2017 | Sony KDF46E2000 46" Projection HDTV
Sony bravia 46" remote control turns on the TV but no other buttons work
First, change the batteries on the remote with e new set of batteries. Check to see if you can bring up the menu using the buttons on the TV itself. Let me know what happens
Sep 25, 2008 | Sony BRAVIA KDL52XBR2 Television
Sony bravia 46"
It sounds like either the remote is bad, or this TV may have a "showroom" setting to keep people from messing with th TV while it is on display. I would download the manual to see if it mentions a showroom setting, if not, try a new remote
Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there.  Worked for us - got the idea from another fixya post.
Jul 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
55 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
