Question about RCA TruFlat 27F520T 27" TV
No picture or audio - just a "feedback" kind of noise
I own a rca tru-flat tv, i turn on tv and there is no picture, only a hi-pitched noise
  • 579 Answers
SOURCE: TV will not come on
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
Posted on Jan 03, 2008
  • 159 Answers
SOURCE: when my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
Posted on May 02, 2009
SOURCE: my 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
my 36" rca green light blinks 3 times, no picture or sound
Posted on Jun 02, 2009
SOURCE: fpa lock on my rca tru flat tv
here is my solution. somebody either needs to give me a solution without a remote or fuckin mail me a remote. and if i ever run into these RCA dipshits, ima beat some ***** *** for puttin the damn lock on there in the first place.
signed,
Jay and Silent Bob
Posted on Feb 02, 2010
  • 903 Answers
SOURCE: rca tru flat tv has a red picture
Is your video input (from cable or satellite or fiber optic, etc.) coming from a coaxial cable, a component cable (red, green, and blue connectors), or an RCA cable (yellow connector for video)?
If you can, try an alternate input method and see if that makes a difference. Does it happen when watching DVDs or tapes, or when playing video games, or just when watching television?
Posted on Aug 30, 2010
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
I have no control over my TV.
This kind of symptoms appears when System Control IC have cold solder joints. Please check below picture mentioned IC101 to be resold in your TV main board.
If you have good soldering skills and familiar with TV, you can do it at your own.
Good luck.
Sep 29, 2008 | RCA TruFlat 27F520T 27" TV
How do i turn off the fpa on my tru flat tv
this is what I found http://www.ehow.com/info_12211261_fpa-lock-rca-televisions.html
Feb 20, 2015 | RCA 20" Tru Flat Color TV with Remote
Hi: My Magnavox flat screen turns on and off. It also makes a high pitch noise and then there is no sound and it also shuts off. Is it worth fixing?
Hello, what's the model or size of screen for the magnavox, the high pitch noise could be an audio power amp starting to get intermittent, and the power on/off could be due to the over current sensor circuit detecting the audio problem. Depending on the model number you would have a seperate power, audio and signal board in the TV. If he TV is 27" or smaller all these circuits are part of a mother board.
Jul 28, 2010 | Televison & Video
I have an LG Flat screen TV approximately 4 years old. It has developed a high pitched vibrating noise which is coming from the sound and not from the TV itself if that makes sense. If you turn the sound...
It sounds like the problem is caused by bad filter capacitors in the power supply section. Do you get the same problem when you use the audio line level out RCA jacks, if you don't, then the problem is in the power amp sections, the TV uses Class D power amp to drive speakers.
Oct 28, 2009 | Televison & Video
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
May 01, 2009 | RCA 36F530T 36" TV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Loud sound, No TV Picture
Power supply needs to be replaced - common problem with these tv"s
Sep 18, 2008 | RCA 32F531T 32" TV
My rca tru flat is NFG
The high-pitched squeal usually indicates that the horizontal drive circuit has failed as a result of a dead line-output transistor. This symptom indicates that the control circuit of the main power supply is trying to over-compensate for a greater than usual secondary current. Certainly, an inspection of the line-output transistor will show that it's most likely dead. Sometimes instead of the squeal you will hear hiccups instead. Focus your attention on the horizontal circuit.
Jan 06, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat  27F520T 27" TV Logo
101 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
