Question about Acer Aspire 5100 Notebook
Screen is loose
The screen of my laptop is loose on the right hinge.  How do I tighten this?  Can't seem to find the screws; are they under the round rubber things(?) at the corners of the screen bezel?
There's no problem with the display.
    Novelist:
  • 69 Answers
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to  loose of screen on right hinge. I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
There are no troubleshooting steps are available for this issue. Since, it is not recommended user level steps. And the issue needs the assistance of Onsite technician. So I suggest you to visit any service center of Laptops, and get it solved as soon as possible. Moreover, currently, it is primary issue and not a major issue. Donot Prolong  the issue as it could effect the display, once if it effects the display then I am sure that the situation could turn worse and requires more than $300 to repair it. So it is better to get it solved now. I guess it would cost for you around $100 .
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Oct 20, 2007
Loose hinges and screen trim comin off
screen trim should be able to be pressed together from front to back, loose hinges is caused by the screws at the hinges. you can pop the trim all the way off normally either by unscrewing the screws or in the case of most hp netbooks by simply applying some pressure between the 2 halves of the screen casing. i'd remove the front half and tighten the screws and then pop everything back together.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Dec 12, 2013 | HP Pavilion DM1-4050US 11.6-Inch Laptop
MBP screen hinge tightening
Hinges are located under the lcd screen and go into the bottom of the base or palmrest. You'll need to remove the strip that is right above the keyboard that normally houses the power button on most laptops. The strip might be secured by screws that are on the bottom of the laptop. Be careful removing the strip, most times there is a cable attached to it under the bottom. Once the strip is removed the hinges are exposed. Just take a phillips head screw driver and tighten them.
Mar 27, 2012 | Computers & Internet
Loose case round himges
The screws that secure the hinges to the body of the laptop may be loose. In this case tighten the screws.
If the hinges are faulty, they are not adjustable and they need to be replaced.
These WEB site can assist you to replace the hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Feb 15, 2012 | Computers & Internet
Case loose round hinges
If the screws securing the hinges to the base of the laptop is loose then tighten these screws.
Hinges have no tightening adjustments and loose/faulty hinges need to be replaced.
These WEB sites can assist you to replace these hinges.
Feb 15, 2012 | Packard Bell Computers & Internet
My screen is loose, i would like to know how to tighten the screen..
You can take the laptop apart, and try to tighten the screws of the hinge. But i think the hinge is worn. You can try if the warranty covers it.
Good luck, and i hope this was helpful ;)
Apr 19, 2010 | Acer Aspire 5610-4648 Notebook
Laptop hinges are loose
The hinges can be loose in two different areas, but the most popular is the hinge attachment point behind the screen bezel. Remove the rubber screw covers from the bezel, remove the screws, take your finger nailas and from the inside of the bezel pull gently to the outside to release the catches on the screen lid. Start on one side and work your way around the screen until the bezel pops loose. Look at the bottom of the screen and you will see the hinge attachment points. Tighten them up. If you have some locktite this would be a good time to apply it, remove the screws one at a time and replace. To replace the bezel, always start at the bottom and work your way up.
Jan 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
Monitor on laptop seems to be loose. screen messing up. is this a simple fix?
yes just take outter casing off and tighten up screws, if they wont tighten up anymore you may need new hinges, cheers
Dec 12, 2009 | Acer Aspire 6930-6771 Laptop
HP DV9000 My laptop screen is loose i would
When the laptop is flipped over, remove the battery. Under the battery there are 6 screws placed in pairs, these have to be removed. Once these are removed, the speaker and power strip can be pryed up, start with your finger nails on the right side and pop it off. Be careful with the flat cable in the middle of the strip. Tighten the screws for the display there and I think there are some that tighten from the bottom. Also, remove the rubber pads from the screen bezel and remove the screws from the screen bezel, then pry the bezel off at a corner and work your way around the bezel until it is removed. It will somply snap back on when you are finished. Tighten all the screws you see that connect to the hinges, this is wher the screen loosens alot. Just pay attention to the wires that feed through the bezel from the screen to the motherboard. Take your time, nothing to it.
Aug 22, 2009 | Frigidaire FRT17G4B Top Freezer...
Sony VGN AR630
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Jul 23, 2009 | Sony VAIO VGN-AR630E Notebook
Fujitsu Siemens Laptop loose screen
some hinge screws are under the power button bar,over over the keyboard,also in back or under the unit where the lcd is located
power button bar is also the hinge covers this pops out , but may be screws on bottom holding it
Jan 04, 2009 | Computers & Internet
Acer Aspire 5100 Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
