Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
No access at all but power light is on
On Thursday I did one of those usual OS updates, but after that my external hard drive would no longer connect to my Mac. My external hard drive is a Buffalo and has no firewire so I have to connect via a chord. The power light is green and happy but the access light only shines for a few seconds as I switch it on, then nothing. I have tried the HD on my work PC and same result. I bought a new connecting cord and same problem. What can I do? I am not very computer savvy so I am sorry if this sounds daft :-( Thank you in advance!
  • alt18 May 26, 2009
    Hey Chris,
    Thank you. It appears it may have something to do with the Mac OS update. Buffalo says my HD is too old or something like that.
    Thank you again!
  • 696 Answers
Using the work PC did you see the information bubble informing you that windows found new hardware?
If so, the problem is likely just a logical issue(damage to the information on the drive), if not then the buffalo enclosure may have failed.
Either way, please reply back with this information and I will be happy to give you the appropriate next steps.
Chris
Posted on May 26, 2009
Just bought a blackweb 2tb {bw-hdd6200-2tbgb} external hard drive and the driver did not install. it shows up in control panel but not in my computer. i cannot access the drive at all...please help
what os are you using
win xp and win 7 are not longer supported by Microsoft so you have to go to the manufacturer web site, find your model hard drive and download the driver that is compatible with your win os as drivers for those 2 os are no longer in the os systems
Apr 12, 2018 | The Computers & Internet
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
I have the simple tech 1 tb external hard drive, I updated my mac OS and now my drive can no longer be read or opened???
Apple will recognize a FAT 32 format. Connect the drive to another machine - a PC. Copy your data to this computer, format the drive to FAT32, copy your data back and it chould be accessable to the MAC system again.
Sep 23, 2011 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
External Hard Drive not Accessible after Windows Vista Update
Assuming that the external hdd is physically working fine, everything is pointing to a damaged boot sector.
You can get back most (if not all) your data stored in your external drive with the help of an application called: Pc Inspector File recovery.
Its a freeware.
Here is the link: http://pcinspector.de/Sites/file_recovery/download.htm?language=1#
Simply install it on your C:\ drive, and follow the prompts.
Please let us know the outcome.
Don't forget to rate this answer if it helps
Dec 12, 2009 | Maxtor Hard Drive
Iomega 500 gb external drive no longer mounts on mac os x tiger
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 24, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hi! I have a Rock Mobile External 250gb hard drive that I have reformatted for my MacBook Pro computer. I have used it for about 6 months now. One day I noticed when I turn on the power it took longer and...
Its in your logic board controller issue, usually the problem is like that but to see what is the another problem of your External Drive is to make or use any diagnostic freeware program to identify the device where it really connected in your PC. I have also encountered like your problem but I send my External to Electronic Tech to check the power connection and controller connection going to PC. Because you said that the hard Drive is still have a normal sound then it is working then but cannot see in your Computer. Try to Diagnose first before you bring to a Technician. Good luck!
Jul 29, 2009 | Computers & Internet
Computer no longer reads drive
It sounds like a permissions issue, allways repair permissions after an update and dont use the machine while installing updates. If it will not repair permissions from disc utility then boot from the install disc, select language and on the page that appears there is a menu bar at the top, select utilities and disc utility and use that.
Apr 03, 2008 | Toshiba 200GB USB 2.0 Portable External...
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
303 people viewed this question
Top Acomdata Computers & Internet Experts
terminalcon
Alun Cox
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
