Home | Refrigerators | Refrigerator is not coo...
Refrigerators
Problem for Kenmore Refrigerators
Generic problem for all Kenmore Refrigerators
Refrigerator is not cooling as normal.
By ihenterprise on May 25, 2009
The fridge started not cooling properly about a week ago. I removed the bottom piece from the front of the fridge and vacuumed lots of dirt from around the radiator like thing. Now the freezer has frost at the back of the inside and certain items are not as frozen. Please help and reply to IHENTERPRISES1@cox.net
Sponsored Links
Clarification Request
Posted by Jimmmyj on May 25, 2009
Sounds like the defrost timer is not operating correctly
Solution #1
posted on May 25, 2009
Not Rated)
Bat1956
Rank: Guru
Rating: 90%, 290 votes
Jimmmyj is probably on target with the timer.
All frost-free refrigerator-freezers have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. The Defrost timer in all boxes fails eventually from old age. When that happens, the coils frost over until they become pretty much just a solid block of ice. Most timers are located on the front of the machine, behind that removable grille under the door. The timer has a round hollow shaft through it, and can be turned with a screwdriver. If the compressor is running, give the shaft a slow twist until a click is heard. The compressor will stop. Give the fridge an hour to defrost the coils, and check it to see if it took off running. Sometimes the nudge will make the timer run for a while. If this is the case, the unit will chill, and buy you some time to get it fixed. If the timer does not run, you can repeat the process daily until you get a replacement timer. If the unit does not chill, there is some other problem either with the defrost heater coils, or the thermodisk. Be advised, all that ice may overflow the pan under the unit.
Was this helpful?
Yes
No
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
We need a new fridge. Saw a Jen Air scratch & Dent model # JF12589 AEP for a resonable... (More)
Answer
which brand of refrigerator is the best?
Answer
I own a true 2 keg beer cooler and it has recenty been not able to turn off the cooler and freezes... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore Refrigerators:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Kenmore
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
