Question about Apple iPhone Smartphone
Iphone 2g,home button does not working.
How can I fix home button for iphone 2g,version 2.2 ,modem fw 04.05.04
    Problem Solver:
  • 18 Answers
Go to http://www.pdasmart.com for your iphone solutions. They work on pretty much everything. They do not charge anything to look at it.
Posted on May 25, 2009
    Sniper:
  • 50 Answers
This may require a new flex. This piece of flex comes from the motherboard under the battery and down to the bottom where on it is included the home button and charging block. It will also have the microphone and speaker attached to it. It is a fairly complex job to be attemted by yourself and I would suggest bringing it to a mobile phone repair centre.
Can i unloceked my iphone
That depends on the firmware and modem firmware version on the phone. On the iphone press the settings button, then go to General, then press About. It will have a firmware version and a modem version further down. if the version is 3.1.2 or lower, and the modem is not 05.12 or higher, you can. If you have FW 3.1.3 or version 05.12 you cannot currently unlock your phone. Take a look over at remondpie.com for unlocking instructions and programs.
Jan 30, 2010 | Apple iPhone 3G Black Smartphone
Tip
How To Fix 1601, 1602, or 21 Error Codes During iPhone 3.1.2 or 3.1.3 Custom...
Are you trying to downgrade or restore your iPhone or iTouch from the official 3.1, 3.1.2 or 3.1.3 Firmware to a Custom Firmware and your iTunes displaying the following 1601, 1602, 16xx or 21 error codes? iH8sn0w has just released a utility named iREB (iTunes Restore Error Bypasser), which provides a workaround to fix these errors.
iREB is available for both Windows and MAC Operating systems. Tool runs on both iPhone & iPhone 3G with Firmware 3.1, 3.1.2, 3.1.3, and also on iPod touch 1G and 2G.
So here is the work around for 1601, 1602, 1604, 16xx or 1621 Error Codes…
New version of iREB is out for 3.1.2 Devices… If you’re upgraded to the latest firmware (3.1.2 or 3.1.3) you should use this download / tool for the errors you’re experiencing. New version has additional devices and more options available.
1. Download iH8sn0w’s iREB 3.1.2 archive for Windows or Mac.
2. Start iTunes and put your iPhone in Recovery Mode; to do so, hold Home and Power button in your iPhone simultaneously and release Power button after a while (10 seconds approx). Keep on holding Home button, till you see following error message appearing in iTunes stating.
3. Now close iTunes and start iREB, following interface will open.d00f484.png
4. Now select your plugged in device in iREB 3.1.2 and it will then show the White creen after few seconds. This happens fast so if you didn’t see it don’t worry… You will also hear sounds (maybe) like your iPhone is being plugged in and unplugged from your computer… That’s normal… The ih8sn0w.exe will crash… That’s normal, as long as you get a white screen…
5. NOTE: If you still don’t see the WHITE screen, you should do this… While the device is still plugged in and iREB running, put your device into the DFU mode. PRESS and HOLD both buttons on your iPhone for 12 Seconds and then release the POWER button (Located at the top of your Device) while still holding down the HOME button… Hold down the HOME button for 30 Seconds… (Yes 30 Seconds) until you get the WHITE Screen, the iTunes will come up with a message stating it found an iPhone in Recover Mode… At this point you can let go of the HOME button… you will be asked to restore this iPhone… and the iREB tool will crash
6. Now start iTunes again and select your device (iPhone/iPod) from iTunes DEVICES tab.
7. To restore original settings on your Apple device, press and hold left “OPTION” button on the keyboard (“SHIFT” button for Windows), iTunes will give you option for Upgrade and Restore, click on “Restore” option in the iTunes and then release the “OPTION/SHIFT” button. Select .ipsw file and restore it
on Jul 08, 2010 | Cell Phones
Iphone 2g not starting back up after reboot..
When the device is locked up like this hold down the lock and home buttons. After a few seconds the device will turn off, immediately let go of both buttons. Now press down and hold the home button. Hit the power/lock button one time. Continue holding the home button until the phone boots up. It will need to be connected to iTunes for recovery at this point.
Jan 27, 2010 | Apple iPhone Smartphone
Is a 2g touchscreen compatible with a first gen Iphone? Will it work if I buy the part on my 1gen phone?
Do you mean a replacement glass to put on your 1st gen iPhone? It can get a bit confusing with the 'Generation' labelling, as 2G in fact refers to 1st Generation iPhones (any prior to the 3G, hence 2G - it relates to the data connection protocol more than the hardware version).
So, with that in mind - am I correct in assuming that you have seen a 2G screen for sale?
If so then yes it will work on your 1st Gen (2G) iPhone. I haven't compared the 2G/3G screens that closely, but I do know some of the sensors are located in a slightly different position on the 3G which may in itself be an issue.
Let me know if you want me to further investigate and I'll help if I can!
Oct 28, 2009 | Apple iPhone Smartphone
I have a 2g iphone, The home
Connect the phone to your computer and iTunes. Click on the phone icon and tell it to revert the phone to factory settings. You likely updated to a firmware that started giving you problems. If your phone works fine without the updates, then don't download them. Some problems the firmware is causing is that the home button is pressed but the screen stays black. The phone has to be reset by holding home and the top button down for 7 seconds to restart the phone. Reverting to factory settings should resolve the problem.
Oct 21, 2009 | Apple iPhone Smartphone
Iphone wont turn on
hey mate.. what you need is,
Turn on your itunes, and when the iphone is off, press the round button (home button) for 15seconds and without releasing the button, plug it in your computer with itunes running.
Once you see the startup of the iphone, release the home button.
Then after that click shift on the computer to restore to the previous version.
good luck..
Sep 10, 2009 | Apple iPhone Smartphone
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 27, 2009 | Apple iPhone Smartphone
Iphone does not ring when in sleep mode
This seemed to work for me;
1.) Reset the phones network settings
2.) Reboot the phone
3.) Put the phone in airplane mode
4.) Reboot the phone
5.) Take the phone out of airplane mode
6.) reboot the phone.
I read this on another website, and it seemed to work for me.
To reboot the iphone hold down the sleep/wake button, and the home button at the same time for 6 seconds (until the apple logo appears).
Good Luck!!
Jul 27, 2009 | BoxWave Corporation Apple iPhone 2G...
2g home button don't work need some help
is this an ipod touch or an iphone? did you drop it? did anything act funny gbefore it quit workin? please give me all the information you have on it. ie any previous damages to it.
Nov 10, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
330 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
