Question about NetGear WGR614 Wireless Router
Moden and Router aren't connecting to wireless laptop
My PC is connecting just fine, but my laptop is not. I recently received a new Arris Modem (TM502G) and have a NETGEAR Wireless Router (WGR614), and now I can't connect to my wireless internet. Help!!!
  • 14 more comments
  • jeaniek572 May 25, 2009
    No. It says my "Wireless connection is now connected", but it won't display a web page.
    And, I've already hit the reset button on the modem.
    McAfee
    When I click on to see my Wireless Network Connection Status, it switches from "Connected" to "Aquiring network address"..is this a possible configuration issue?
    Nope! No Wi Fi...
    OK..it did show a completely different number ...
    I have a wireless adaptor in the laptop...BTW, it worked just fine prior to me getting this new modem..
    Ok, I've followed those 3 steps, where would I look for the IP address?
    IP is 72.129.55.254
    Gateway is 72.129.48.1
    My laptop has an autoconfiguration IP address that is 169.254.32.89 and an IP Address of something crazy...fe80::21b:77ff:fe16:a4cc%7 and no Default gateway!! ??
    Ok..I have the "blue" Internet cable coming out of the computer...that is connected to the Arris Modem. Then I have another "blue cord" connected to the "internet" jack on the Netgear Router. Where should the end of that cord be plugged into?? I have only 5 plugs on my Modem...1 where the actual cable screws into, the 2 prong plug, 1 ethernet jack and 2 phone jacks.
    Nope! That didn't work either. In fact, I wasn't able to get the internet on either computer. The only way I get the internet at all is if the blue cable that is connected to my computer, is also connected to the modem. If I connect it into my NRTGEAR, I'm not connected at all. =(
    Correct! The only way I get internet at all is if the cable is coming from the computer into the ISP modem.
    A yellowy-green-ish color, but, again, no internet connection.
    Could it be that I need a new router?
    Our internet was acting up, so my roommate got a new modem..but I suspect it was most likely the router. How do I go about getting a new one?
  • Michael Rodriques May 11, 2010
    What anti-virus/firewall software are you running on the machine?
    Are you getting any kind of error messages?
  • 111 Answers
It sounds like the router is working OK, so there's really no need to reset it. Here's some things to try, in order:
1 - Click Start, then run. In the box that appears type cmd and hit enter. This will open a DOS Prompt. At the prompt type ipconfig and hit enter. Your IP address should read 192.168.1.(some number). If it shows anything else, this indicated that you are not getting an IP address to the device.
2 - Click Start Control Panel. In control panel go to network. This will show you your available network interfaces. Reply here with the connections that you see in the box.
Posted on May 25, 2009
  • 8 more comments
  • Michael Rodriques May 25, 2009
    OK. That means that the PC is not getting as far as the router. Do you have the machine plugged in, or do you have a wireless adapter in the laptop?
    Did the new modem come from your ISP? If so, did you reset the entire network when you got it? You do this by tuning off all network equipment, then restarting them in this order:
    1-Turn on your ISP's modem. Wait three minutes
    2 - Turn your netgear box back on and wait two minutes
    3 - Turn your PC back on and see if it gets an IP address.
    Comment here when you do that.
    Click Start Run type cmd and hit enter. type ipconfig in the dos box that comes up. You should have a listing in there for your wireless network. What does it say for IP address and gateway.
    OK. the ip address of 72.129.55.254 indicates that the machine giving you that IP address is plugged directly into your ISP's modem and not the router. Can you confirm this? If this is the case, here's what you need to do. Your ISP's modem should have an ethernet jack on the back of it. This looks like a phone jack but a little bigger. There should be a cable coming out of this and going into the WAN or internet port on your D-Link router. From the D-Link, there should be a cable connecting to the computer that is reporting the 72.129.55.254. Check that and let me know if it is connected as explained here.
    OK That's your problem your network is wired incorrectly. Here's what you need to do.
    1 - Take one cable and connect it from your ISP modem (ethernet port), to the internet port on the D-Link box. Now. Run another cable from one of the other hacks on the D-Link box to the back of your computer.
    2 - After you do this, turn off all netowk equipment (modem, router and both computers) then turn on the modem, wait two minutes, turn on the D-Link box wait 2 minuted and finally turn on both computers.
    After you do this, both systems should be able to connect to the internet.
    You had the cable coming out of the ISP modem to the internet port of the router, and then another going from one of the router ports to the computer and it didn't work?
    If you plug the ethernet cable from the computer into the router (not the internet port), do you get a light on both the router and the back of the computer, and if so, what color(s) are they?
    Yellow or green is OK on the computer. What about on the router? When you plug that in, do you get an lights that line up with the cable you plugged in? I would expect no internet while you try this. I'm trying to determine if the router is functioning correctly. As an aside, why did you get a new ISP modem?
    Thats' what I'm thinking. If you get anyting other than a green light when you plug in to the routers hub side (not the internet side), then your router is probably toast. Why did you get a new modem from the ISP?
    Staples or Office Depot is fine. I'd recommend this one. I would agree with you on the router being toast. A new router should plug right in and run OK. The come with software but DO NOT use it. Just cable from the modem to the internet side of the router, then the hub side of the router to the computer and you should be OK. Remember that you need to reset all of the equipment after replacing it so they see the new router. The order is Cable Modem, wait two minutes. Router, wait two minutes, then computer.
    Good luck, and you can email me at miker@otunet.com, or reply here if it doesn't work.
  • 58 Answers
I know i sounds stupid but the first thing you need to know is; does your computer have built in wi-fi. alot of the time built in wifi seriously craps itself...
if so, then you'll have to get yourself a usb wi fi adapter
ok... the second thing is do you have your security settings on right if not you need to type in your ip address into the adress bar on your internet browser ( the password and username should be; "admin" as your username and "password" as your password if they aren't then you'll need to contact your service provider for info.) once you've gotten ther you need to go to "Wireless Settings" and choose "WPA-PSK(Wi-Fi Protected Access Pre-Shared Key)"...
if that doesn't work please feel free to pm me for help... =]
    Scholar:
  • 66 Answers
I would just try holding the reset button in for 10 seconds on the router. it would be the easiest and first step towards solving the problem.
We recently got an Arris TM722 modem and a netgear wireless-N 150 router WNR 1000 after getting a new ISP. My problem is that every time I turn on my xbox to connect to xbox live, my xbox doesn't connect...
Recheck your settings on the xbox.
If using wifi on the xbox, you'll have to setup a new connection to the new router.
If the xbox is wired via cable to the router, you may need to add a router password or other settings .
Jun 21, 2017 | Computers & Internet
I have my main computer set yp with arris router
  • You can use both Ethernet and USB interface to connect two PCs simultaneously with one cable modem.
  • If you plan to go wireless (and maybe connect more computers), you have to purchase a router to split/share the internet connection coming from the modem.
Apr 07, 2010 | Arris Touchstone 450a (CM450) Modem
Can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
Link light blinking
On these cable modems the link light is supposed to blink when you are connected to a router/pc. If you are hooking up a wireless router new you need to power cycle/reset your cable modem before you hook up the wireless router so that way it can refresh its ip address.
Mar 21, 2009 | Arris Touchstone 450a (CM450) Modem
I have aa Arris modem connected to a lyksys router. My laptop connects via the router. It was working fine until yesterday. Since then the signal is very low on the laptop connection and keeps throwing me...
Try to power cycle your modem and the router for 2 minutes and If your Arris modem has a battery back up on it you must remove it in order to refresh the settings on it.
Keep in mind that after the cycle period you must turn On first the modem and make sure all lights of it are completely stable before powering up the router.
Mar 06, 2009 | Linksys Wireless-G WRT54G Router
Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Mar 01, 2009 | Arris Touchstone 450a (CM450) Modem
Installing wireless connecton with an Arris modem
what type of modem are you using? You should be using a router which is capable of wireless connectivity....
Keep me posted
Cheers
Jun 21, 2008 | Computers & Internet
NetGear WGR614 Wireless Router Logo
627 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
