Question about ATI RADEON HD 2400 PRO Graphic Card
CONNECT 3D RADEON 9550 256MB display problem
CONNECT 3D RADEON 9550 256MB AGP 8x/4x INTEL PENTIUM 4 3.00GHz Mercury board with 4x/8x AGP Slot Mercury PC333 512mb RAM Mercury TV-TunerCard SAMSUNG 80GB Hard Disk Windows XP SP2 DirectX 9c all going fine but suddenly when i play a game about 5 - 15 min the display struck and change to 640 x 480 from onwards every operation is slow on monitor. after restart is work again normal till i play a game for another 10 min. but i watch TV there is no problem when i play game it struck and i cant set 640 x 480 with 16bit color in secondry also. Plz help me to solve this problem. anandhtrichy@gmail.com +91-9894511438
  • 1 more comment
  • anandhtrichy May 27, 2009
    thanks mates! my cabinate have 3 cooler fans still the problem exits.
    Using OS --> Windows XP SP 2
  • veer01_42 May 11, 2010
    Did you update the driver for all the parts? What operating system are you using? Open the casing and put a fan on it and see if that helps
  • QuackWare May 11, 2010
    Is this an on board graphics card or one you put in a pci/pcie slot?
    Also your graphics card might be overheating, there are several programs available which show you the temperature of your card. Just Google them. If its ridiculously high like 50-60C you need a better way to cool your case
  • 86 Answers
That graphics card i'm afraid is not good for todays games, same thing goes for your pentium 4. A driver update may fix your problem but that card and cpu need changing, probably a new motherboard would be needed also to fit a pci express graphics card along with a core 2 duo processor.
Posted on May 27, 2009
I HAVE A HUGE PROBLEM....I HAVE AN ELITE MOTHERBOARD L4VXA2 AND WAS WORKING FINE WITH AN ATI RADEON X1300PRO GRAPHICS CARD 256MB AGP 8X....BUT AFTER SOME TIME...I HAVE A PROBLEM.....I PRESS THE START...
Hello and Welcome to FixYa Alex.
No, the battery isn't the problem as you stated that without the Card your PC runs smooth, what i can guess is that the Graphic card is gone, and to confirm this you need to cross-check it on some other PC that can support it. If on that PC the problem is same then its clear that the Graphic Card is gone. And I guess you know that if a Graphic card is of 8x Video output interface, and the Board interface is of 4x, then the Card will run under the compatibility of 4x. A 8x Graphic Card is actually 4x/8x Graphic Card.
I hope you have a clear picture now, and yes I know you will be wondering that how come the graphic card can burn, then fellow never ever trust electronics, they are arbitrary.
If you have any questions do ask, I'm here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Jul 31, 2010 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Graphics card support to motherboard D845GBV
AGP 2.0 and 3.0 4x and 8x feed with the 1.5v spec. AGP 1.0 1x and 2x was fed at 3.3v. In short, you should be fine.
May 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site: http://www.colordrives.com/sapphire-ati-radeon-9550-256mb-ddr-agp-4x-8x-video-card---retail-box.html
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
VIDEO CARD COMPATIBILITY
All AGP based cards are backwards compatible, so an 8x card should operate at 4x 2x and 1x
however what is important is the voltage of your slot, you can tell by looking at the slot itself,  the AGP slot may have a partition either 1/3 or 2/3rds down the slot, or may have no partition at all,
this slot partition is to prevent you from inserting a card of the wrong voltage.
If there is no partition in the AGP slot then the slot has a switchable voltage, and will automatically switch to the appropriate voltage, (on request from the graphics card AUTOMATIC)
so all you need to check is that the graphics card you buy has slots on the AGP interface that accomodate those on your board
according to the manual
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=413&areaid=2&LanID=0
This board has a 4x AGP slot
Oct 09, 2007 | Intel Motherboard
Does my (this) mother support agp ddr2?
MOTHERBOARDS Hi there, does my motherboard support video cards like ATI RADEON X1650 512MB AGP? ---YES, When you installing AGP card, please make sure the following notice is fully understood and practiced. If your AGP card has "AGP 4X/8X (1.5V) notch"(show below), please make sure your AGP card is AGP 4X/8X (1.5V). Caution: AGP 2X card is not supported by Intel® 845(GE/PE) / 845(G) / 850(E) / E7205 / 865(G/PE/P) / 875P. You might experience system unable to boot up normally. Please insert an AGP 4X/8X card. Does it support ddr2 or ddr3 memmory for the agp? ---YES, see the above notes can the agp memmory be over 512 mb? ---YES, see the above notes More more information go here >>> http://asia.giga-byte.com/FileList/Manual/motherboard_manual_8ipe1000g_e.pdf Hope This Helps =============================================== If you are having trouble with a Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
AGP video Board recommended for PC Chips M925 V7.3
FOR YOUR MOTHERBOARD , ITS BETTER TRY NVIDIA GEFORCE CARDS LIKE GEFORCE MX4000 , FX 5200 , 5500 , 6300 BUT DONT USE SLI CARDS , THEN ABOUT YOUR ASUS RADEON ITS ADVICED THAT ASUS RADEON 9200 WILL WORK BETTER WITH INTEL MOTHERBOARDS
Aug 23, 2007 | PC Chips (M925G) Motherboard
ATI RADEON HD 2400 PRO Graphic Card Logo
345 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
