Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Cannot watch 780 or 1080 resolution video, but can watch 480
Mitsubishi WS65869 Big Screen TV. Connected to high definition satellite TV, low resolution can be seen fine. When the channel is changed to high resolution, the picture looks like a lack of horizontal sync for a second, then it turns to the blue screen with the error message Check connections or power RGB may be invalid. I started noticing these problems after I replaced a convergence IC and after I upgraded to High definition Satellite TV. I am wondering if this may be a problem with the capacitors on the DM board, as I did experience a flashing green LED, but seemed to solve that by making sure the back cover of the TV was on, and there was no external light shining on the back of the TV as I thought there may be some light sensitive optocouplers in the circuitry. When I pushed the TV back to the wall and dimmed lights, my flashing LED was solved.
  • Richard McDermott May 26, 2009
    Thank You, I will check it out with the ICs. I believe my the real solution to the failure to watch HD was that the "Native function" of the satellite box was set "on", and the 720P was also set on. Once I resolved these two settings, I was able to watch 1080i video. Thank you for your solution of the solder joint and IC for the real reason of the flashing green LED.
    Brigadier General:
  • 8,619 Answers
Hi
The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. Pushing the TV back might have solved the problem for some time; I believe you should check for cold solder joints.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on May 25, 2009
My picture is blurry,and words are blurry,what do i do
A blurry image on a high-definition LCD TV is typically the result of a mismatch between the TV's resolution capabilities and the resolution of the signal that is coming from connected devices, such as a DVD player or satellite TV receiver. Typically, blurry pictures result when a peripheral device connects to the TV through nonHD cables and jacks.
If your TV's connected devices do not have HD capability, they will transmit content to the TV in standard, analog signals. These types of signals are only capable of resolutions of up to 640 by 480 pixels. Pixels, for picture elements, are the tiny dots that make up the screen image. Most HD LCD TVs are capable of resolutions of as low as 1,366 by 768 pixels and as high as 1,920 by 1,080 pixels. When this big of a discrepancy occurs, the images display on the TV scaled, stretched and blurry.
Jan 24, 2015 | Televison & Video
Tip
Youtube Trick I
You may notice just under the lower right coner of the video window, some videos have an option to “Watch In High Quality”. By default, these videos will play as a 320×240 FLV file
at 320Kb/s. Check out this sample:
http://www.youtube.com/watch?v=zyyjgYcS8Fs
The user could click on this link to “Watch in High Quality” which will reload the video and play the MP4 version , which is 480×360 at 512Kb/s. By adding &fmt=18 to the end of the URL, you’ll make the URL you share with others bring them right to the high quality version. Here’s the same video in the High Quality view:
http://www.youtube.com/watch?v=zyyjgYcS8Fs&fmt=18
What else are you gaining besides increased video resolution? The video is compressed with H.264 compression, so you get better video even at the same data rate. You also go from a low fidelity mono audio feed to stereo @ 44.1Khz sample rate.
&fmt=6 increases the resolution from 320×240 to 448×336, Flash 7 video @ 900Kbps; audio @ 44.1KHz 96Kbps Mono CBR.
&fmt=18 increases the resolution to 480×360, H.264 video @ 512Kbps; audio @ 44.1KHz 128Kbps Stereo. Note, the bandwidth may be lower, but it’s utilizing a more efficient compression codec .
&fmt=22 increaes the resolution to 720p HD video if the source was uploaded at a high enough resolution.
on Dec 16, 2009 | Computers & Internet
Cannot view camcorder slides on television taking film of holiday but cannot watch on television as all fuzzy
Unless you have an HD (High Definition) camcorder, the resolution of the video (or pictures) taken may be too low for it to show well on a (large) TV screen. Hence, you'll see the videos/pictures as blurred/fuzzy
Jun 22, 2010 | Samsung Video Cameras
What is the screen resolution for this set - Insignia NS-27RTV
Standard definition is 480. This TV has 500 lines of resolution. Detailed specifications can be found in the owner's manual, under the Support tab.
Jan 28, 2010 | Insignia NS-27RTV 27" TV
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Satellite input
Most tv setups require that you change the input source to gain the ability to watch the proper peripheral e.g. if satellite is connected on video one and the dvd is connected to the tv on another input such as video 2.
If the satellite runs into the dvd unit and from there the dvd is connected to tv you may have to power off or on the dvd player to resolve conflict.
Another problem may be the resolution setting if your tv is Hi Def. Set the tv and receiver to the resolution e.g. 1080i.
You can also changed the way the satellite is connected to the tv possibly if you have other inputs.
Check the channel also, if the unit is connected with coax it would more than likely need to be on ch 3 or 4 if you are at the satellite receiver box location. If you are at a stand alone tv off of a dual tuner you may need to search the channels for the right source both air(analog) and cable(digital).
Hope this helps you out. If I can be of more assistance let me know.
Sep 07, 2008 | Proscan PS60690 60" Rear Projection...
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    Help with my big screen mitsubishi ws65869 tv
    my screen is a right blue with no picture although I have sound it reads "tuner out"
    Mar 27, 2008 | Mitsubishi WS-65869 65" Rear Projection...
    Mitsubishi ws65869 big screen tv
    Does the LED power light come on? Have you checked the fuses?
    Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
    Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
    46 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
