Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Driver lose after setup windows I need to reinstal full option were in device to my pc but I lose it driver. help please
  • thavovi May 25, 2009
    even i downloaded it to my pc but I can not printing, scanning and copying, what's happen and how to solve it?
    President:
  • 987 Answers
    President:
  • 1,383 Answers
Tip
How to install device drivers using driver files without a setup
Obtaining drivers is a very important aspect in the everyday use of a PC since outdated drivers need to be updated. Drivers can be downloaded from many different sources on the internet and through many third party software programs. Whatever the source, there are a number of times that people download drivers and they realize that what they have obtained are just the raw driver files without any setup. A lot of people get stranded in such cases. The following, is a very simple way of installing these driver files:
Whether under Windows XP, Windows Vista or even Windows 7, do this:
1. Click on the start button and right-click 'My Computer' or 'Computer'.
2. Select manage and wait for the resulting window (if asked whether to continue, continue).
3. Select 'Device Manager' from the left panel.
4. Now, depending on the device you want to install the driver for, or update its driver, right-click the device (you may have to click on the plus sign to reveal hidden devices). select the first option (update driver software) from the drop-down options.
5. In the case of Windows Vista and Windows 7, select browse my computer for driver software and then browse for the folder that contains the files.
6. In the case of Windows XP, select the last option which avoids the internet and click next and select manually locate files and next. Now add the location of the folder that contains the driver files.
7. Click next and Windows will automatically install the driver files for your device.
8. Restart your PC and you are done.
This procedure is not necessary when a setup file is available unless the setup file is corrupted but the driver files are available.
Hope this was helpful and all the best.
on Feb 19, 2010 | Computers & Internet
Eee PC 1800HA can't go through windows xp installation
You have a "Driver Issue", generally a "Display Driver" but not always, what you need to do is start PC in "Safe Mode" Press F8 at turn-on, and then remove the display adapter from device manager and reboot, windows will then install a"Generic" driver and ya should be able to get to desktop to get the correct driver, and install. Sometimes it is faulty components too. But it seems ya may be past this point seeing as ya tried to re-install XP on it again... not the best way to handle it, but of course ya didn't know that.
However since ya have tried a setup ya may be in a bit of trouble. I think maybe ya only option is to Format the drive... and totally reinstall Windows XP. (Or ya just gonna have endless trouble). Use the DVD that came with ya PC and reinstall it.
Jan 24, 2010 | ASUS Eee PC 1000HE Netbook
Need to get driver updates for my pc without
If it has effected your display, are you able to read progs? if so try " Device Manager" Locate monitor/display/ reinstall/might do the trick. if not try
a "RESTORE" ?
If running vista, restart, clicking F8, takes you to repair menus. Try the first which is a self repair. Then restart
Failing that and you are able to backup all your important date/files on external HDD.
If you still are not able too, and you have the setup disc's, you will have to reinstall, there is a repair option before the full replacement, but it will knock out some data/files, hence suggestion to backup if you can?
Nov 14, 2009 | Computers & Internet
If I do a windows complete PC restore,will i lose all my saved files?
If you do a System Restore using Windows own program you will retain all of your files
If you do a repair via the Windows disk you will save your files
If you do a full re-install using the Windows disk all bets are off
It is safer to back up onto memory pen or DVD all of the files which matter to you and then do the re-install , you will need a bootable copy of the Windows disk and a copy of the disk containing the drivers for the Motherboard etc
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Audio Driver Problem
i guess some of your device drivers were corrupted. what I can recommend you is that you reinstall your windows XP with an "R" (stands for repair) option (which will rebuild your OS without losing any of your files and settings).
Jun 26, 2009 | HP Compaq d530 SFF PC Desktop
Missing or corrupt hal.dll file, so can't boot the hard drive
Hey,
Please use the recovery discs or windows installation cd.
To either perform a full system restore with the recovery discs.
Or to perform a repair installation with the windows installation cd.
Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Thanks and good luck.
Ekse
May 03, 2009 | Dell Dimension 3100 PC Desktop
No sound
after downloading drivers,open the setup and install it to your PC.Check the sound card.the installed drivers must be suitable for your sound card.not all drivers will operate on your sound card.if still problem persists try installing vista.
Sep 21, 2008 | HP Compaq Presario V2000 Notebook
Accidentally disabled graphics
Turn on the Pc & as it starts press the F5 key every 2 seconds. A window will open with a list of start options. Select VGA mode. You'll have to use your keyboard's up & down arrows here. Press enter to load VGA mode. Once in windows re-in able
graphics driver. Re-start windows. If that fails. Repeat the above to get back into windows. Re-install video drivers. Than restart the system.
Post back if your still having trouble.
please vote....
Feb 19, 2008 | Computers & Internet
EmachineT3256 Windows XP Repair?
try this:
1. right any where in desktop except on start menu
2.go to properties
3. go to desktop tab
4.go to customize desktop
5.now select desktop icons like my computer,my documents etc..
give ok
now you will get those icons..
if you want to reinstall the windows means no problem you can reinstall
the repair option will come...
boot from dvd (make sure by going to bios setup first boot device is cd/dvd device)
then you can follow instruction from the set up wizard
Feb 16, 2008 | Microsoft Windows Xp Home Edition Sp2...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
54 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
