Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Hearing headphones hooked up to hd tv which has to run on component and has no sound now
Our tv has to be on component now in order to get hd tv from direct tv. We have hearing headphones for my husband and unable to get sound through them now
  • 42 Answers
What connecttion on the TV are you using to connect the headphones?
If its the Component Audio In, this wont work as its only an input not an output. If your TV has a headphone connection, use this.
Posted on Jul 16, 2009
  • Siobhan Mack Jul 16, 2009
    If
I HAVE A 2006 SAMSUNG DLP HL-S7178W {73" PROJECTION TV},IT WILL ONLY WORK ON AIR 3, COMPONENT 1,NOTHING, COMPONENT 2 HAS PICTURE,BUT NO SOUND.I PURCHASE A "CHEAPER" REPLACEMENT BULB INSTEAD OF A SAMSU
If anything were bad with the lamp or ballast, the TV would not have a picture, and would shut off in 30 secs. I think on these component 1 does not run HD inputs--only 480i +480p (progress. scan DVD). Component 2 runs up to 1080i HD but not 480i SD, I think. Your no sound must be something else.
Oct 18, 2014 | Televison & Video
Sennheiser 126 connect to tv
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
Nov 07, 2013 | Sennheiser Audio Players & Recorders
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
I am trying to hook the Philips 30pf9946 up to an HD Tivo
I am wondering what you are making the connection with, If you are using s-video or composite from your tivo to your hd tv it will only produce 480i. in order to get 480p and above you will need a component video cables or better(hdmi) in order to produce the signal. You may have already known this, but I couldnt tell be the information provided. Hope this helps.
Jun 20, 2009 | Philips 30PF9946 30 in. HD-Ready Plasma...
Sound quality/ connection to tv/ audio problems
The sound quality from an HDtv could very well be better than from a lesser-quality TV. The sound from the headphones can only be as good as the signal that feeds it.
Apr 26, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
No sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Hooking up cable through ht-x50
You need an Optical Audio Cable. Hook one end to the HD Cable Box and the other to your Surround Sound System. If you dont have an Optical Cable to your Cable Box, then try using the usual audio cables. But, I have HD and it worked with the Optical Audio Cable.
Dec 05, 2007 | Samsung HT-X50 System
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
234 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
