HDD from dell optiplex g1
I formatted a HDD and I want to put XP on it and use as primary HDD. My primary I use has Win95 on it and has missing Dll files. I want to replace it with the HDD I formatted.  Where do I put it to install XP.  I need an OS to do that.  When I put the formatted HDD in primary position I don't have an OS so it just sits there.   Help!!!
  • john yates
    john yates Oct 21, 2007
    Thanks,I'll print this and take it to the shop.I plan on setting up a pc on my shop with a router as I have DSL here in my house
    You are always helpful and I do appreciate all.  Thanks Lots
  • john yates
    If you would walk me through how to choose to boot from cd. I have a heck of a time in BIOS.  Make it easy for me.
    Scholar:
  • 155 Answers
You can connect your HDD as primary or secondary, doesn't make any difference, anyway as you said I also suggest you to put it as primary. When you insert the Windows XP installation disk and you boot from your CD-Rom it will shows you all the disk and partition asking where do you want to install it.
(To boot from CD you have to enter in the BIOS and change the device priority at boot, let me know if you know how to do that)
At this point from the installation of XP you select your HDD, select to format as NTFS (Better then FAT32) and you start the installation.
At the end of the installation Windows XP will modify your MBR (Master Boot Record) to add a dual boot including Win95.
Be carefull that at  the end of the installation from XP you will be able to read files on the old HDD containing Win95 but not viceversa, because Win95 cannot read NTFS partitions.
Posted on Oct 20, 2007
  • Massimo Ardito
    Massimo Ardito Oct 22, 2007
    When you power on your PC you should have a message like "Press DEL to enter setup", in some other PC instead of DEL is F2 , Compaq use F10. So if this message is not hidden (It's another set up in the BIOS) you should be able to see it at the bottom of your screen as soon as you power on your PC and complete the memoery test. Even if you don't see the message keep pressing the DEL button on your keyboard as soon as you power up.
    If you are pressing the right button you should enter in the BIOS menu.
    Look for something like
    and using the arrow keys and enter select your CD-ROM as first boot device.
    If your motherboard is little bit older you may have this type of BIOS
    if this is your case use your arrow keys and enter and go on Boot Sequence and change with CD, C.
    Remember to save before exit!
    Keep me posted.
How can i install windows 2000 in a dell optiplex 3020?
If you want a clean install just format your XP drive. Then boot with your 2000 cd in the drive. Make sure it is bootable and your bios is set to boot from cd.
Jun 17, 2014 | Dell OptiPlex 3020 Mini-Tower Desktop 3.2...
I removed my HDD from my PC and put it into another old pc. Then I replaced it again in the original. Now the mouse won't work
in this case,when you put your hdd in dell optiplex you must reinstall your windows,because the dell optiplex is a build up computer.
if you want more clearly detail you can contact me to my email
Dec 27, 2013 | Computers & Internet
Install a 2nd hdd (sata) on dell optiplex 360 not working
Can the disk viewed in disk management?
Right Click 'My Computer'-->Manage-->storage-->Disk Management
Disk 0 usually for windos partition (your 80GB HD)
If Disk 1 (your TB HDD) show unallocated, you need to format it to NTFS.
Right Click and select 'Format'.
!!!!Make sure it is your TB HDD!!!!!!!
Jun 08, 2012 | Dell OptiPlex 360 Desktop Computer
My dell optiplex gx520 has detected sata hdd on bios but cannot boot. i have been compare the hdd to another dell cpu and its work.
the reason why windows won't reconize it as a boot drive is because you have to format the harddrive to NTFS. You have to connect it as a secondary drive on another machine and format it. To do this you have to
click on start, right click on 'computer' and click on 'manage'. Once on 'computer management' click on 'disk management' and select the disk you want to format, right click on it can click 'format'.
Hope this helps.
Mar 20, 2011 | Dell OptiPlex GX520 PC Desktop
Computer will not boot up
This is because of either the system has shutdown while it was processing a windows file. sometimes repairing the OS or running a CHKDSK /R in the recovery console will fix this problem. if that doesnt help i recommend you change your HDD
Sep 16, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
Reinstall windows xp pro
How far through the setup does it get?
Have you done a full format on the HDD?
Does the HDD detect in the BIOS? Is it a confirmed working drive.
Aug 22, 2008 | Dell OptiPlex GX620 PC Desktop
Samsung 200gb hdd
When u bought a new hdd, it shud not have any partition on it. but in ur case, I assume u have formatted it to ntfs but no operating system is installed in it.
If u want to make the new hdd as slave and have another old hdd as primary, that have already an operating system installed in it, then the problem shud be hdd boot priority in bios. Enter ur bios and check for hdd boot priority and put the old hdd to the top most order, then restart. this shud fix the problem.
If u installed OS in ur new hdd (win xp),
1) ntldr or ntdetect.com is missing on root dir. (c:\). If u have another computer that works and have xp installed, just put this new hdd along with the current hdd and boot to windows. Copy ntldr and ntdetect.com to your new hdd. Or another way is just repair using windows xp boot cd.
2)the windows partition is not set 'active'. to set active, boot into winxp setup and press 'r'. this will lead to recovery console. type ur passwrod for admin (def=none). use diskpart command to set active. for easy way, put the new hdd to another computer. boot to windows. rightclick my computer, choose manage. on left pane select disk manager. rightclick on ur partition, then set active.
Hope this help
May 08, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
481 people viewed this question
Alun Cox
David Payne
David Payne
