Question about Car Audio & Video
Keeps blowning tail light fuse
Put in a new panasonic radio and it keeps blowning the tail light fuse on my nissan bluebird?
    Problem Solver:
  • 6 Answers
Sounds like you have connected your illumination/park light wire to earth the stereo. try disconnect the black wire from your stereo and reconnect it to a metal earth point on the dash, if this works just tape up (insulate) the wire that was the problem.
This is a common problem when fitting stereos as the illumination wire will go to earth when not switched on.
Posted on May 25, 2009
  • 1,889 Answers
Reconnect the hot wire to the ignition switch only
Fuse for tail lights keeps blowing
You have a serious short circuit in the wiring to the tail lights. Fuses protect the wiring in your vehicle from catching fire.
You need to trace the tail light wiring from the fuse box to the tail lights to locate the fault/short circuit.
A wiring diagram can help as it shows the colour code of the wires to the tail lights.
This problem can be difficult to trace and you most likely need an auto electrician to fix this problem. It could mean installing a new wire to the tail lights as a quicker fix and bypass the fault..
Apr 19, 2013 | 1993 Nissan Quest
I have no tail lights when i turn on my head lights
check your tail light fuse, or blown bulbs. Just do a small test before you strip. Put someone in car turn ignition on and just apply brakes, if the brake lights come on means you have tail lights bulbs blown . If you have no lights at all go again for bulbs or fuse.
Aug 25, 2012 | 1995 Nissan Pathfinder
I have a 1997 Nissan Sentra and I recently put in a radio. The wiring went great and everything was put like it was suppose to but that night as I was driving I realized that my dash lights would not turn...
Check fuse number 36 in the fuse block. It supplies power for bothe the interior lights and the running lights. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Jan 19, 2012 | 1997 Nissan Sentra
I have a 1995 nissan pathfinder. i keep have electrical issues. when i first got it two months ago it wouldnt start. replaced battery terminals and it was fine for a while. then the meter fuse would blow...
It sounds like just the one problem. Your tails and the dash illumination lights are all on the one circuit that the fuse keeps blowing. Don't get confused thinking of another main fuse, just focus on this one circuit..
It is very seldom that a short develops at the fuse box, it certainly can happen from corrosion or loose terminals, but it is rare. More likely is a bad wire just like the one you found near the exhaust. Somewhere very likely a wire has had insulation stripped or scraped off, soon as the wire touches metal it will blow the fuse. Were any other wires damaged in that harness for the speed sensor? Or do you see any wires hanging down from under the truck, anywhere going back to the tail lights?
If you did the stereo yourself, were any wires cut going to the dash? I doubt this as the wire for the dash lights would be in a wiring harness that is like a bundle from under the dash up to the instrument cluster. You just have to keep looking for the short.
Mar 17, 2017 | 1995 Nissan Pathfinder
Interior lights and tail lights don't go on for 2002 nissan sentra
you most likely have blown 10amp fuse for tail lights in the fuse box under the hood as far as tha tail lights go. turn your lights on and check your tail lights along with the plate lights. plate lights are on the same fuse as the tail lights. there is a fuse box by the battery which has tail light fuse in it. the lid of the fuse box is showing location of fuse. as far as your interior light goes, make sure that you have the switch in "door" position or it will not come on when door is opened. or just put it into "on" position to see if it comes on. but turn it off or put it back to "door" position/middle seting or your battery will drain down.
Oct 01, 2011 | 2002 Nissan Sentra
I put a new radio in my 2002 maxima and now tail lights are out and dashlights also
I HAVE SEEN THIS BEFORE. THE GROUND WIRE FROM THE NEW RADIO IS PROBABLY HOOKED TO A WIRE. IT SHOULD BE FASTENED TO SOME METAL FRAMEWORK UNDER THE DASH. IF THAT IS THE CASE, RELOCATE THE WIRE, REPLACE THE NECESSARY FUSES, TAIL LIGHT &/OR INSTRUMENT.
Jan 07, 2011 | 2002 Nissan Maxima
Replaced tail light fuse, which turned on tail
most likely you have a short in one of the bulb connectors or the hot wire from them is pinched on medal somewhere. Or you have water intrusion shorting one out. Inspect the bulbs. Leave both bulbs out. install fuse. Press brake pedal several times and hold. Inspect fuse. if its blown its the pedal switch that's bad or a pinched wire from there. If good put one bulb in. Test again,, then the next bulb. If you see something obvious fix it.
Jul 18, 2009 | 2004 Nissan Maxima
Tail light fuse keeps blowing
Terry: It's obvious I'm not dealing with a USA spec car, however, I had lived in the U.S. Virgin Islands and am quite familiar with the Bluebirds of the past. Nissan still uses the same basic circuitry designs as far as what circuits serve what. Here are the circuits to look at.
All lights which are switched on by the headlight switch. This includes the Cigarette lighter back light, radio light power supply, automatics have shifter back lighting as well as your climate controls and all dash lights. Your side marker lights are also served by this circuit. The dash lights go through a type of dimmer switch which essentially creates resistance, thus dimming the lights. Sometimes the clocks are tied into the circuits. Start with the simple things first and work your way in. There is a type of fuse called a circuit breaker which will plug into the fuse block in place of the fuse.
Get the same rating as the one you pulled out. DO NOT USE A JUMPER WIRE AND LET THE SMOKE OUT OF THE WIRES!
If the circuit breaker blows immediately, you have a serious short!
With the circuit breaker, if the short is not real bad, the lights will burn for a little bit before the breaker blows. Once it cools, it will close and the circuit will operate again. While it is in operation, you look for the lights that operate and the ones that don't. Check the ones that don't. Although it's rare for a bulb to cause a fuse to blow, it does happen.
I often find problems are due to radio installations or other types of installations. So if you don't have a factory radio or if you have some type of accessory which has been installed in the console or dash, this would be a prime suspect. Nissan's are not really known for electrical problems unless they have been in collisions. If your car has been in a collision, look in the area where it was hit. You may find a pinched wire or damaged insulation. I am not quite sure what model your car would compare to in reference to a US car.
The Bluebird's were 510's. Are the Maxima's now? What ever model it is, unless it has no sister model imported to the
USA, the odds are that the circuits are going to be real close if not identical! I hope I have been of some assistance. Let me know.
May 23, 2009 | 1996 Nissan Sentra
96 bluebird le grand tail light fuse keeps blowing?
Anytime a fuse constantly blows, you either have a short in your wireing for that components circuit or the component itself is faulty. Inspect the wiring harnesses for each taillamp assembly and ensure no wires are damaged or loose. Also inspect wiring at the fuse box.
May 23, 2009 | 1996 Nissan Maxima
Nissan Quest 2004 Tail Lights
Robynumber1,
Thanks for the email back. The nissan quest tail lights werenot operating, but the break lights were working. This was ultimately caused by a blown fuse. The fuse was blown by loose trailer lighting wires dragging on the ground, thus shorting. Problem fixed.
Aug 17, 2008 | 2004 Nissan Quest
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
