Whirlpool LSN2000JT1 I put a load of laundry in and it filled with water but it won't agitate it just makes a loud GRRRRRRR noise. What can I do?
  • cogprob Dec 22, 2007
    Whirpool washer - will not work. on/off control placed in any position except stop causes timer to come on, but nothing happens. top of agitator spins by hand freely in one direction only. Bottom is frozen.
  • 248 Answers
  If it also doesn't spin ,  you probably have a bad coupler.  This located between the motor and the transmission.  If it still spins you probably need to replace the agitator dogs.  These are located in the top of the agitator.  If you can turn the top of the agitator freely in both directions,  the dogs are worn out.
Posted on Oct 21, 2007
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WHIRLPOOL TOP LOAD WASHER MAKING GRINDING NOISE FOR AGITATION
When you put the motor in did you replace the coupler between the motor and transmission? When fixing the agitator you need to get the agitator repair kit, It has seals, dogs,thrust plate, cam bearing and seals. The upper agitator is supposed to move only in one direction to get the clothes to move down towards the agitator. Do not overload machine. I have one of these and after 12 years I finally had to install this upper repair kit because the upper agitator quit moving. You may have an agitate cam that is going bad inside the transmission
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
MY WHIRLPOOL LAUNDRY MACHINE WILL NOT AGITATE
If it just fills and stops dead then its probably the door switch.If it fills and you hear the motor start and it makes a horrible noise then its probably the coupling between the motor and transmission. Theres also a slight chance its a stripped agitator spline
Apr 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine will not agitate, but it allows the water to drain.
soundsas if you have possibly broken youor motor coupling( this machines "belt") easy repair, yo can see video as to how to replaceit by searching you tube for whirlpool motor coupling
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
We have a Whirlpool Gold Ultimate Care II Washing Machine. Washer will fill with water, but when it tries to go to another cycle you just hear a loud rumbling noise and the basket will not spin.
Peace jjones16 ,
huuum At your service!
You have a Whirlpool Gold Ultimate Care II Washing Machine. And the washer will fill with water, but when it tries to go to another cycle you just hear a loud rumbling noise and the basket will not spin?
Correct?
So!
Sounds like the coupling connecting the transmission to the agitator is worn out!
If I were there hands on I could be definite.
But it sounds like you need this replaced!
Thank God it's not the transmission.
When a transmission goes out of warranty, it;s not worth putting good money into bad! They are just to expensive a repair!
Only a hands on laundry tech can make the diagnoses.
This time you should call service
Let me know what is the final results.
Please write me back.
How old is the washer??????????????
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You,
huuum
Please give me a good rating before you sign off.
Thank You
Sep 12, 2008 | Whirlpool Washing Machines
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
