Question about Ryobi Garden
Replacing Drive Shaft for a Ryobi 725r
My lower (flexible) drive shaft broke on the string trimmer attachment for a Ryobi 725r. How difficult (and expensive) is it to repair? I think maybe I can get a completely new attachment for $60 to $70. The trimmer is about 4 or 5 years old. Should I repair or replace?
  • 376 Answers
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
Posted on May 25, 2009
How do I remove the shaft from my trimmer
String Trimmer Drive Shaft Replacement - Poulan Pro ...
? 2:18
www.youtube.com/watch?v=A_Sv1S7r_-o
Mar 4, 2013 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing the lower drive shaft on Poulan string trimmers. The .
Jul 28, 2015 | Garden
Ryobi weed eater upper and lower shaft spins, but head doesn't spin, why?
If not a clutched model, likely the flexible drive shaft is broken. Check 1st to insure the engine head is firmly positioned into the aluminum shaft case. If it is remove at the engine, disconnect the cable as necessary and pull out the shaft for close inspection.
May 02, 2014 | Ryobi Garden
How to replace flexible drive shaft on Poulan Twist n Edge, TE 450 CXL LE string trimmer. I have removed the lower string assembly - can't remove shaft.
Shaft needs to come out the top, will have to split the case or remove motor from shaft to pull cable out
Aug 29, 2011 | Poulan Garden
How to replace the lower flexible shaft
Hi enriquemon,
To remove the drive shaft, loosen the clamp that is just above the protective shield and remove the set screw attaching the drive shaft tube to the trimmer housing. Remove the drive shaft and if you want clean and inspect for damage. You are installing a new one so it is not an issue. Coat the shaft with a high quality, multipurpose lithium grease. Make sure the ends of the shaft are properly located in the drive adapters when assembling. Depending on the amount of time it is used, the drive shaft should be cleaned and greased every year or two. I hope this is helpful to you. Any questions welcome. All the best and good luck.
Feb 19, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The flexible drive shaft broke near the bottom. I have removed it from the motor end and pulled out whats left of the shaft, but cannot figure out how to get to the broken end so that the flex shaft can be...
I believe what you need to do is remove the 3 screws on the trimmer head to remove the head from the lower shaft. After the head is off you can look down into where the shaft goes and be able to use some needlenose pliers or something of the sort to pull the broken part out.<!-- from fixya rte -->
Jul 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
Ryobi 700r how do you replace flexible drive shaft. Boom and trimmer get very hot after the trimmer runs for a while. I think the flexible drive shaft needs to be lubricated. I can not figure out how to...
it comes out but you have to lossen the screws holding the engine on at the base and pull it out? the other end has a locking nut remove the spool and loosen
Aug 27, 2009 | Garden
725r trimmer
You can buy new Line to re-spool on your existing head
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Engine runs but no power to the head
It could be simple. Sounds like the drive cable came loose or broke. You could get an estimate from a repair shop -- probably not terribly expensive.
May 08, 2009 | Garden
Garden Logo
1,352 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
