Question about Sony VAIO VGN-FJ170/B Notebook
LAPTOP OVERHEATS AND COMPLETELY SHUTS OFF
The fan on my laptop is running consistently and loudly and after having my computer on for a while, it overheats and completely shuts off until it cools down, (and when I say hot, I mean it'll burn your hand if you touch the bottom of the computer "hot"). How do I make it stop?
  • Yohann Lewis May 25, 2009
    I have the same problem but on a Toshiba and its really annoying once it turns off once it keeps on turning off every 10 mins and my computer has to keep started up again
  • blueextc3221
    blueextc3221 May 11, 2010
    sounds like your processor fan has quit.
    try blowing compressed air in to dislodge any lint buildup - not canned air - COMPRESSED air :D
    President:
  • 272 Answers
Have you cleaned it lately? If not that's what they sell those cans of compressed air for. With your computer off bloe the air through all of the vents you can locate to get all of tha accumulated dust that is blocking the airflow out of there!
Posted on May 25, 2009
  • 34 Answers
Remove the bottom case, clean the cooler and the heat sink. Then apply thermal grease (to the heat sink, the part that has contact with the CPU).
If none of the above work, you should try buyin new heat sinks and /or cooler.
  • 105 Answers
Get some canned air and clean that puppy. alternative for $20 you can get a laptop cooler pad. plugs into usb. any department store has them.
NP-RF710-S02US OVERHEATING WHILE GAMING
Try air in can or a vacuum cleaner to remove dust from the fans on the back and/or side of the laptop. If its overheating then removing this dust could provide better ventilation and cooler laptop. Also using laptop on soft surfaces, like bed, makes it overheat more.
Feb 07, 2013 | Samsung NP-RF710-S02US Notebook PC - Intel...
My x205-s9349 toshiba laptop is getting hot in the area of #1 hard drive and shuts down. I have vacuumed the case out and still does the same thing. this laptop has run hot ever since it was new.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this. Use a fan assisted laptop cooling pad for addition cooling.
May 29, 2011 | Toshiba Satellite X205-S9349 Notebook
The laptop overheats and then shuts down
Hi joshua1156,
Your laptop fan is not working. That's why the laptop overheats and shuts down. Replacing the fan will solve your problem.
Thank you for using fixya,
Arun Zac
Nov 26, 2010 | Gateway 7320GZ Notebook
I have a compaq presario f700 and it never overheated until one day i played a game on ninjakiwi.com called SAS zombie assault 2. Now when i listen to music on windows media player or watch videos on...
Insufficient information, but try this for starters:
Make sure the laptop sits on a hard surface and the fan vents are not covered/clogged.
1) Run windows only on a fully charged battery and see if it overheats
2) If not, run media player only, and look for the same
If it overheats in either step, you have a hardware/software problem.
Hardware problem could be that the fan has failed completely and needs to be replaced.
Software problem could be incorrect fan settings, although I do not think you can turn the fan OFF on a laptop.
IF the laptop overheats in Step 1, I would definitely suspect a hardware problem. In that case, run the laptop but do NOT log into windows. Go into the BIOS (check fan settings in there, if there are any).. leave it running in BIOS and see if it overheats then.
Aug 18, 2010 | Computers & Internet
Runs way too hot, overheats and shuts down. Besides geneal external cleaning hints, any suggestions? Like how to run fans at max rpm always? Or how to open it up to thoroughly clean it?
Check that all of the air vents are left unblocked and that your fan is spinning and expelling warm/hot air. It is recommended you use your laptop on a hard flat surface to ensure some airflow under the laptop. You could try purchasing a can of compressed air and blowing it into the vents to loosen up any built up of dust and hair.
If you are skilled enough you could open the laptop up to completely clean the fans and heatsink. Whilst it is open you can remove the heatsink, clean the old thermal paste off of the CPU and GPU and apply a very thin, evenly spread layer of fresh thermal paste. Then put the machine back together.
As for the fans, download a free application called SpeedFan and read through it. It will monitor your core temperatures and it has some options for controlling fans if your hardware allows it.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite U405D-S2852 Notebook
My computer overheats and shuts off.
A few things you can do to improve the situation
Switch it off and get a can of compressed air meant for cleaning computers. Take it outside and with the nozzle on the can spray inside all the ventilation and cooling slots but do not poke the nozzle into any of those. That usually chases out the dust bunnies.
That in itself may help if you saw lots of gunk coming out.
Now go get yourself a cooling pad with at least 3 fans and one that has its own power supply too. It should also be capable of running from a usb port.
NEVER run a laptop while it is sat on ANY soft surface eg bed, cushion, carpet, etc etc. if you have to run it without a cooling pad then make sure it is propped up slightly at the rear to aid air flow
Aug 20, 2009 | Acer Extensa 5620-4677 Notebook
Toshiba A65-S1062 - This laptop overheats and shuts down.
I bet that you had your laptop on all the time.
Your heat sink is saturated with dust and grit.
you may have to open up the unit and use a can of dust remover to clean the fins on the heat sink out. it is causing your CPU to shut down bucause it is becoming overheated.
Happy Fixing =)
Jul 11, 2009 | Toshiba Satellite A65-S1062 Notebook
M6307 Gateway Laptops overheats and shuts down
Have you called Gateway? This is definitely a mother board or CPU problem, both probably caused by a slow acting fan. Gateway should replace these.
Jan 05, 2009 | Gateway M-6307 Notebook PC
Laptop overheats way too fast...
What is the model number of your machine? Some have design flaws that make them run hot. Also dust is a great insulator. I would take the machine into a repair shop or get a can of compressed air and blow out any fan areas. A laptop cooling pad can be a good idea as well especially if you notice that the machine overheats while sitting on a desk. The noise of the fan is probalay due to the dust coating the heatsync. The fan has to run much faster to move more air to cool the system. Blowing out or having the heatsync cleaned is a good idea here!
Dec 06, 2007 | Computers & Internet
Sony VAIO VGN-FJ170/B Notebook Logo
300 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
