Question about Olympus FE-340 Digital Camera
Camera wont focus or stay on
When I turn on my camera the lens goes in and out three times and the lcd screen is blurry and when I go to zoom in or out to focus the camera switches off.
  • sbarrile May 25, 2009
    Didn't work.
    Thanks anyway
  • Richard Schabler May 11, 2010
    http://www.youtube.com/watch?v=EEDL48cKH... I see your camera, as per my previous "Clarification Requets" your camera has three cylinders on the Lens Barrel, (The part the goes in and out) Try to observe the direction the middle two lens barels move when you try to zoom. They will move in or out, but also spin, try to observe the point when they stop moving and the camera shuts down. My advice would be to try to assist the twisting motion back into proper alignment, since the lens has most likely been "assisted" out of alignment, Be gentle, and don't get carried away. The proper direction would be a tiny bit back from where the Zoom function takes it. (it sounds like the zoom function is trying to travel beyond it's reach) Perhaps to check, look and see if the lens achieves a full zoom before it shuts down, or if it can't move fully into zoom position. The most likely result will be a request to turn off the camera (or auto shutdown), and turn it back on again. These devices are smart, but they don't go far from home. If you do manage to move the barrel, (a few clicks will let you know), and it dosn't operate better . . attempt to move the barrel back to where it was originally. One step forward, one step back. Always check that you get at least the minimal functions you already have. Good luck, Richard.
  • 744 Answers
Hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on May 25, 2009
  • Prakash Ram
    Prakash Ram May 25, 2009
    hi...The transmission system that moves the lens in and out has a
    problem with it's gears. There is most likely a gear or an actuator
    that has fallen out of alignment and is getting stuck at a certain
    point as the lens comes in/out.There is some disturbacnce of the lens
    arrangement that is preventing the lens from coming in/out.Any of these
    symptoms above could trigger the camera to shut itself off to protect
    itself from further damage.
    thank u rate me!!!
I just had that problem and fixed it by turning on the camera and then rotating the lens ring closest to the camera clockwise just until it click once or twice which extended the other two lenses out all of the way then wiggle the other two lightly. I then turned the camera off then back on and had to repeat the previous again. Then shut it off and turned back on. Something in the lens rotation must have been slightly off. Just play with slightly rotating the lenses like that until they get into the right position. Make take a few tries, just don't overly force them. Wish I had tried this on my other camera before tossing it out because it had the same problem.
Posted on Aug 15, 2012
Blurry images
Sounds like a lens problem. If you've ever let the camera "auto turn-off" as a power-saving measure, any button pushed will turn it back on...even if it's in a case or your pocket. This puts strain on the lens as it tries to come out...result....lens problems.
Nov 13, 2009 | Panasonic DMC-TZ4 Digital Camera
Ok so i am turning on my camera (an Fe-340) and the lens go in two or three times then when the screen finally does come on it is blurry and way out of focus, also when i attempt to adjust the zoom the...
It may be something more serious, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Sep 06, 2009 | Olympus FE-340 Digital Camera
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Jul 13, 2009 | Olympus FE-230 Digital Camera
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
My fujifilm S1000 keeps saying "Zoom Error"
same problem camera was dropped and have zoom error, since the lens and lcd are FINE i dont think it will be that much to fix
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
Kodak easyshare c533 lens is stuck
after 4 seconds view screen pic melts and goes blurry
Oct 19, 2008 | Kodak EasyShare C533 Digital Camera
Repair lens PDX10
It sounds like the optics in the lens are no longer calibrated. It needs to be looked at by a professional.
Oct 10, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
No picture and lens does not retract
Well some cameras has features that does not use the LCD screen of the camera, because to save battery power or to get better shots with the focus ring.
You can just use the area where you focus your eye to aim and shoot the object of image.
Try to enabled the LCD screen feature.
The Zoom Lens Wiggles 3 times because it is programmed to zoom at the standard zoom size, this is totaly normal for camera in digital and analog types.
Mar 05, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Olympus FE-340 Digital Camera Logo
577 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
