Question about Alpine CHA-S624 6-Disc CD Changer
Disc changer the cd player is not pulling the disc out of the cartrige into the actual cd player
  • Anonymous Nov 02, 2007
    alpine compact disc model # s604 not ejecting the magazine stating error 01
  • Anonymous Mar 16, 2014
    I have to pull the disc out with butter knives, it will not eject properly. It just makes a clicking sound.
  • 199 Answers
Hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
Posted on Mar 07, 2008
Yamaha cdc 697 cd player wont play disc
There are so many reasons for this fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Sep 14, 2014 | Yamaha CDC-697 - CD changer 5-Disc CD...
My 5 disc CD changer will not eject an hung CD , on an Infiniti 2005 G35,..any solutons???
Some CD players actually have a locking mechanism inside of them. This mechanism can be released by using an unwound paperclip and sticking it into the CD player. There should be a button or platform to push that could release the disk. If that doesn't work, you might want to try using a pair of tweezers to pull the disc. To do this put the tweezers inside the CD tray and try to pull the disc out while pressing down and holding the eject button on the CD player. To me, it sounds like the motor that sucks in and ejects the disc is slowly dying and is having trouble pushing the disc out. If all else fails you might want to take the car to a dealership to see if they can replace your CD player
Oct 19, 2012 | Cars & Trucks
1998 Honda Accord EX stereo/CD player has Code E on the screen... What is the cause of this and what can I do to fix it?
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam and cause the player to display error codes E-01 thru E-07. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 1998 Honda Accord
How do I clean a 5 CD disc changer?
i think the concept of this type of machine is one actual disc reader (the eye needing the cleaning) and a carousel that carries discs to the play position. So a cd lens cleaner can be placed in any of the carousel parts and do as much good as in another, once should be enough.
Jan 31, 2010 | Panasonic SCAK410 5-Disc CD Changer
Car cd changer problem
cd changer not working in leganza
Jun 18, 2009 | USA Spec SCD-D50 6-Disc CD Changer
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
Cd cartrige
Mechanical problems aside, you may have a pickup problem that needs professional help...accordianman
Dec 17, 2007 | Bose Acoustic Wave (32022) 5-Disc CD...
This only happens to me with burnt cd's.
Nov 04, 2007 | Panasonic SCAK410 5-Disc CD Changer
Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Oct 06, 2006 | Technics SL-MC6 CD Player
Alpine CHA-S624 6-Disc CD Changer Logo
397 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
