The unit powers up with screen display ok for a few seconds then goes blank. Sound from channel ok.
  • slehoczky May 25, 2009
    The unit is a grundig amira 30LW 76-9401 LCD TV
    display. If you power up the unit it initially is on
    standby. Selecting a channel powers up the unit and the
    display comes up with the display ok then a few second later the
    display goes blank but the spound is ok. Selecting different
    channels from the control unit changes the channel and sound of course
    but screen remains blank. Turning off the unit a number of times
    eventually clears the problem and the screen remains active. Have
    used different inputs but makes no difference. Once the unit
    poweres up correctly it will run ok until turned off and then the
    problem reappears on the next power up.
    Stefan.
    Novelist:
  • 151 Answers
Its the clear problem of short circuit.i will explain.in the tv on the main board there is a component which is getting short.actually when you ON the unit.it shows display.but as soon as it gets overheated the circuit gets cut and the part shorts.the display vanishes. as you will think that how in such a less time components gets overheated.i will explain.as which part is short .from that part when the current passes at time it cannot go further because it gets short .due to that current getting halted at the same part and not moving further the component gets over heated. as per me its not at all the costly issue to get solved.but its bit tough to find the faulty component from the circuit board.because there are hundreds of such component.now which is faulty can only be located with the help of multimeter.so i will suggest you get it repaired by a local electronic tv repair shop.asmostly 1 or 2 capacitors are getting short.the cost of each faulty part is not more then 5$.plus the service charge of the repair technician.so its worth getting it repaired.it will work properly. this will help you. please do rate the solution.thank you for using fixya.keep updated.
Posted on May 25, 2009
  • 4,472 Answers
First of all what is the make and model of the unit and how long have you owned it. The tv stays on but the video is gone? Have you tried different inputs or different sources, like dvd player etc. Does the menu or anything come up? Once I have more information I can assist you further. Please don't request more assistance until I get a chance to do so.  Thank you,
Lee
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Samsung le40d503f7w only displays samsung logo on screen for a few seconds after switching on and then goes blank
have the same problem, one or more of the flourecent light bulbs in the back panel got broken, looking for a supplier who may keep these bulbs in stock, or other wise will see if i can get a used one off ebay for spares.
Jan 24, 2012 | Computers & Internet
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Sharp aquos display comes on for a few seconds then blank screen
I have the same problem with my 37" HP which is the same as Sharp Aquos, it's bad backlight inverter boards, the screen comes on for a second then nothing, no menu, no channel change indicator then turn it off and you hear the clicking of the power supply about 10 seconds after.
Jan 01, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Blank screen
ok this means probaly ur Operating System has crashed.
If u have a bootable OS Cd-Rom then plz notify me and then i tell u the next step.
Do not install it yourself unless you have done it before.
Jul 22, 2008 | Compaq Evo N610C Notebook
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
