I have a Tascam DR-07 portable digital recorder. It records just great but when I try to save the live music I recorded on the recorder and burn it to a CD the CD will not play back. What extension ie .xxx form should be saved to and can the ms vista standard be able to do it or do I need to buy a burner?
  • richard_pett May 25, 2009
    what is the extension that the
    cd I am trying to burn in order that the cd will work in cd players!
    President:
  • 1,383 Answers
.mp3
.wav
but first try in winxp because vista gives some times error
u can play dvd afdter burn in computer check .
And if u get error in vista run32.dll then it is vista bugs u cam play that files in win xp
Posted on May 25, 2009
  • 744 Answers
Hi..
I have Vista and it works great it just see's it as another drive like a thumbdrive. Hi,
Normally for when you connect any device to pc using USB port, windows detects it. Sometime it may take time.
1) You must have your PDA in ON condition
2) If PDA is not getting connected on port, try connecting to other USB port (assuming that pc normally have more than one USB port)
3) Make sure the cable that you are using between PDA to PC is working properly (normally you can check this by using other cable)
4) If you have intalled some anti virus program on your pc then check the settings of same.
5) last but not least check the settings of window's firewall (part of OS)
If everything of above is fine then either USB ports of pc or of PDA might not be working...
thank u
rate me
Tascam dr-07 when I turn on the display reads system err 50
Kennedy, Do hard reset by hold down the track edit and up arrow keys simultaneously while powering up. It will re-initialize the disk and ask you if you're sure you want to. Ans. yes using the (yes/enter) key, and the unit will re-boot itself and return to the welcome screen as loaded from the factory.
PRESS THE HELPFUL BUTTON
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwji99_noujKAhXKJB4KHctTDsIQFggjMAE&url=https%3A%2F%2Fwww.educ.cam.ac.uk%2Fservices%2Favs%2Floanstock%2Fmanuals%2FUser-Manual-Tascam-DR-07.pdf&usg=AFQjCNEmPJ4OCw7_ULc8zPDMmrafuRMIQw&bvm=bv.113370389,d.dmo
Tascam DR 07mkII Owner Manual Page 116
Amazon com Customer Reviews Tascam DR07 Portable Digital Recorder
Feb 08, 2016 | Tascam Audio Players & Recorders
I downloaded the contents of my Tascam DR-05 to my computer because it was full, but, instead of doing it as always, by just downloading the soundfiles, I copied the file folder dr005 to my computer,
Eric have you tried to do a "Quick Format"? If I'm not mistaken when that is done, you re-format your card and the small memory in the DR05. I had trouble with mine at first but when I did the formatting after I put the bigger 2GB memory card in the DR05 worked great. I record on "All Files" too, that seems to work well also.
Hope that helps,
Patrick
Oct 14, 2014 | Tascam DR-05 Portable Digital Recorder
Voice recorder won't play back sound
Can you put this problem to an expert
Dec 15, 2013 | Tascam Dr-05 Portable Recorder
My tiger direct custom computer running windows 8 cant find my Tascam "linear PCM recorder" even though i have the tascam in USB mode. I've tryind both USB 2.0 and 3.0 and i tried DISK MANAGEMENT but it...
Please try reinstalling drivers . . May be Tascam needs the external power also . . Also make sure what mode is selected on TASCAM . . Sound card or storage . .I have a ZOOM . . . May be this will help . .
Sep 12, 2013 | Tascam Dr-05 Portable Recorder
DR-05 How to delete files
When not in Pre Record o Record mode, you can hit the quick button and the delete option will come up. Then click it and your good.
Jan 12, 2013 | Tascam DR-05 Portable Digital Recorder
Dr-40 stops recording after 5 seconds
Check if your DR-40 has auto-rec turned on. If so, it will only record once a certain input level is present, and will stop if the input goes below that level. The recorder will turn back in when that level is exceeded again.
May 10, 2012 | Tascam DR-40 Portable Digital Recorder
Need the down load sight for the DR-07 digital recorder
The official downloads website of tascam dr-07 is here.
If you need drivers, firmware or software specific for it they are available there.
Regards from FixYa.
**Please rate good if this was helpful for you**
Thanks.
Mar 24, 2011 | Computers & Internet
I have a tascam dr7 with a device error 2 code...I used a 5v power supply not from tascam for quite a lot of time.....it eats batteries like crazy. Device error 2...what is it?
Device Error [2] is "memory bus error". There is nothing that you can do to fix it. There are two PCBs in Tascam DR-07. This is the bigger one that has LCD display and all control buttons. Your best bet is to find a broken one that does not power up at all (the smaller PCB - which host the CPU - is bad) then swap the PCBs.
Dec 16, 2010 | Tascam DR07 Digital Voice Recorder
Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
