Question about Sony Playstation 3 (PS3) Console
When I turn on my PS3 it will not turn on..it auto shuts off with a red light!!!Help!!!
When turning on the PS3 it does not turn on..red button flashes then turns back off!!!
  • texascuz May 25, 2009
    i had same problem, but i didnt play on it for a few months, and now works, so this may be another solution
    Sniper:
  • 64 Answers
You're getting a double beep as it turns off, right? This usually means that your console is not recognizing the HDD (hard drive) for what ever reason. A PS3 will not turn on if it thinks further damage will occur. Here are two things you can do;
1. Try accessing the repair menu. Here's how you do this: With a solid red light showing, hold down both the power & eject buttons. You're going to hear a single beep, then a double beep. Once you hear the double beep, release both buttons. You'll get a message on your TV saying "connect your controller using USB". Following all the instructions will lead you to a 6 item menu. You are going to choose number 3. If that option doesn't work, pick number 6. BE WARNED!!! Number 6 will delete ALL of your saved memory! I know that really sucks, but this may be the only way to save your console short of repair. You can "back-up" your saved data using a "USB storage device" Like a memory stick or even your iPod.
If none of this works, or the console won't let you do the "double button" thing, it'll need to be repaired. You can contact PSR repairs at www.psr1.com. They are really great! They do both warranty & non-warranty repair work for a very decent price. I hope I helped. Good luck, Pam!
Posted on May 25, 2009
  • 5 Answers
This problem usually appear in older versions of the ps3, you can solve this problem very easily.
All you have to do is to disconnect your hdmi cable from the ps3 and reconnect it after a few seconds.
This is called blink ps3, and it has to do with the connection between you LCD TV to your PS3
You can watch here more
Posted on Jun 04, 2010
gamerfixer07
  • 344 Answers
SOURCE: PS3 does not turn on. When I press the on button, red light turns green thne to yellow then to flashing red.
This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
Posted on Jun 25, 2008
sacblietzenn
  • 8 Answers
SOURCE: ps3 automatic shuts off
the problem of your PS3 is inside.. it has a problem on its power. it could be a wire problem or a current electricity problem so visit a PS3 tech. or else you might lose your ps3
Posted on May 09, 2009
alenjogy
  • 123 Answers
SOURCE: Ps3 shutdown?
the chip set in your play station is damaged.
Posted on Jul 20, 2009
  • 5 Answers
SOURCE: when i turn on the ps3 it shuts back off imediatly
Power Supply going bad Or RSX chip separating from motherboard Dreaded YLOD yellow light of death Solutions You tube Fix it yourself or send it off to Sony for them to Fix
Posted on Jul 30, 2010
praky16
  • 744 Answers
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
What to do with a yellow light PS3? or auto shut down?
There's a switch in the back, the only benefit of using the power button is that it can be turned back on with the controller. Don't use the switch when your game is saving or anything is downloading because you could corrupt the saved game/download (I don't think it'll let you turn it off from the front button when it's writing to the hard drive- the switch in the back actually cuts off the power.), also note that When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
Leave the PS3 system off for 30 minutes to let it cool down.
If you continue to have issues, you will have to send the system in for service."
I hope this will help in solving the problem....
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on the green light turns and then turns yellow shuts off and the red light flashes
hello have you tried this press and hold the power button in until you hear 2 bleeps then release the button it should reset the the ps3 good luck
regards
shaun
Jul 30, 2010 | Video Game Consoles & Games
PS3 turned off on its on, now won't turn back on
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
Hope this will help...
May 31, 2010 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont boot..PLEASE HELP!
It's the Yellow/Red Light Of Death. It can be fixed. Go here http://playstationlifestyle.net/forums/showthread.php?t=2376. Follow the videos. A little bit of time and you should be back up and running.
B
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 shutdown?
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
4,521 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
