Question about HP Pavilion dv4000 Notebook
Laptop will not turn on
My HP dv4000 laptop will not turn on. Right before I left for school my old charger shorted out and so I purchased a new one. The new one was the only one i found for HP's but is recommended for the 4200. I used the new charger for a few days at school and again back home for a little while. After about 3 days, my laptop will not turn on what-so-ever. No sound, no blinking power light on the front, no nothing. I have tried switching outlets as well as letting the laptop sit for a few days, but no luck. I would really appreciate any help.
  • 1 more comment
  • paul_apyan May 25, 2009
    I do not have the old charger, but the voltage of the new charger is 19V 4.7A. I have had this laptop for 3 and a half years.
  • Dudeman321 May 11, 2010
    If you still have the old charger post the voltage and current rating of the new and old chargers output please. This will be somthing like 19V 3.42A
  • 230 Answers
The only suggestion I can think of trying is to remove the battery and mains lead from the unit wait 5 mins then plug the mains in without the battery present. If the unit does not start after this then it's likely an issue with either the plug pack or the notebook motherboard. Try wobbling the connector going to the laptop and see if its a loose connector. Get the plug pack tested with a voltmeter to see that it's working.
Has the new plug pack got a removable end piece or is it hard soldered, if it's got a removable end piece has anyone accidently reversed this causing + to go to - or vice versa?
If the above tests don't prove positive then I'd say the unit will have to go in for service.
Hope this helps
Posted on May 25, 2009
Hp dv4000 won't turn on, no lights on- totally dead
first check fuse in plug. if good then check power adaptor, even if its lit up it still can be faulty or use a voltmeter to check that you are getting continuous current. if good it gets harder youll have to open it up and check the fuse inside it dont look like a normal fuse its small. its at the back next to were you plug in the charger should say f. check picture. its not for youre model but just a demonstration. hope this helps. j.oates
Nov 16, 2012 | HP Pavilion dv4000 Notebook
Hi, everytime i turn on my laptop (dv4000) and start using the keyboard it gives me an error tone and that's it it goes wild.The only solution is to restart the computer and use external keyboard...
When a battery will not start a vehicle, it tends to be in the circumstances most embarrassing and frustrating, a school run by a meeting or even work urgently. Call for help from vehicles is not always an option and even if it may take some time to arrive. Rather than leave it to chance, many drivers now carry 85wh apple A1172 Charger for use in such peril.
Nov 15, 2010 | HP Pavilion dv4000 Notebook
The power adapter that plugs into the laptop HP DV4000 is broken, and I can't use the charger. where can I find a new one to replace the broken one, or will I have to buy a whold new charger? thanks
Do you mean only the power cable that linked the power brick with laptop was broken? Of course if you are 100% sure that's the only part that fail, you may only buy a cable. Check this link blow:
http://www.chargerbuy.com/cable-connector/power-cord.html
But if you are not that sure, i'll suggest you buying a whole new charger:
HP Pavilion DV4000 AC Adapter
Aug 03, 2010 | HP Pavilion dv4000 Notebook
I installed a new battery in My HP DV4000 laptop but it won't charge. It's a 8800mah and says 11.1 volts. The old one says 10.8 volts. Any ideas?
this problem happens when the voltage of the battery is slightly less or equal or more than the output voltage of the charger u need a more powerful charger for charging that battery
Mar 31, 2010 | HP PAVILION DV4000 SERIES 30GB (4200 RPM)...
Left mouse isn't working right?
go to hardware shop.some hardware problem
Feb 21, 2010 | HP Pavilion dv4000 Notebook
Cannot find the hpdv4-1125nr wireless button?
It should be on the lower left part of your laptop. It is easy to miss it slides from left to right.
Aug 15, 2009 | HP Pavilion dv4000 Notebook
Replace hinges on a HP dv4000 laptop
Don't worry. HP have a repair manual. You can see the manual firstly.
h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Hope this can help U
Jan 14, 2009 | HP Pavilion DV4000 15.4" LCD LEFT AND...
HP Pavilion Laptop dead?
Try unplugging laptop and take the battery out. Put battery back in and plug back in. If that doesn't work It would recommend taking it to a professional. The good news is that your data on your hard drive should be okay.
Thanks
Todd
Laptop Guy
Apr 23, 2008 | HP Pavilion dv4000 Notebook
Black screen
When you say it turn black, could you try to see that ther are
still picture on it(maybe you've black light problme)...or just completely black .And do your laptop have any activity...say harddisk light still flashing,..etc..
Bye,takecare.
Apr 18, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
146 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
