Question about Haier HWR08XC7 Air Conditioner
Ac unit reset switch keeps popping out
When i turn the unit on the reset botton automatily pops out
    Habit-Forming:
  • 174 Answers
Is this a switch that is built on the cord .if so by pass the switch, or you could buy a new cord.
Posted on May 25, 2009
The reset button keeps popping when I plug in the unit? It won't turn on
when the reset button pops it indicates an over load situation and it works to prevent further damage to the unit
could be a start run capacitor failed or the compressor seized
call an ac technician for a check and a quote
May 28, 2016 | ACE Artic King Window Mount Air...
My reset button on the cord pops when I try to reset it. is it the cord that's bad? if so can you by pass it somehow
Air conditioner's reset button keeps popping out? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 28, 2008 - The breaker went bad recently, and had been replaced. The AC worked great for 2-3 days after. ... Then the reset button in the cords started popping out. ...If this is a window ac with the reset button on the plug, could be that the ... I'd try (after turning off the circuit and verifying, of course) opening up the ...
Quick Fixes for TV Picture Problems - Cox Communications
www.cox.com/residential/support/.../article.cox?...
Cox CommunicationsOct 20, 2015 - Learn quick troubleshooting steps for your TV picture problem. ... TV picture problems often have a simple cause and solution that you can easily ...troubleshooting steps, try our Cable Reset Tool by clicking the button below.
Wall socket buttons: What do the "test" and "reset" outlet ...
Dec 15, 2015 | Heating & Cooling
Reset botton on bosch dryer keeps poppig
this machine is like you it needs to breath like you?
if filter not clean the themostats kick out
so clean the filter and air ways
Jul 15, 2014 | Bosch Nexxt 300 Series WFMC2201UC
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
Pops reset botton after a few min.
Clean any photocell eye this unit may have. If it continues, replace reset control.
Feb 15, 2010 | Reddy Heating & Cooling
My breaker pops when i switch the unit to coo
Sounds like compressor has shorted
Aug 07, 2009 | Heating & Cooling
Please help
what kind of unit is this?The breaker could be popped.
Jul 10, 2009 | Carrier Heating & Cooling
My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Apr 30, 2009 | Carrier BCA101R Air Conditioner
Error SC 541
Try this... Press the Yellow reset botton then the number "1" then "0" then "8", don't hold them down, just push each botton once. Then hold down the "Stop/Clear" botton till the display changes to service mode, then turn the main Power Switch OFF then back On and see if it warm up.... If it dose not warm up you may have a problem with the fixing unit.... Good Luck
Sep 19, 2008 | Gestetner DSM 651 Copier
Haier HWR08XC7 Air Conditioner Logo
346 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
