Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Belt tension adjustment
My Hoover upright vacuum, model U6476-900, has a front agiator belt that is loose and slips on the agiator so it will not turn under a load. I replaced the beld, 385280-34, but its the same problem, too loose. Is there a tension adjustment on the tension roller? How is this tension problem corrected?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
If you are looking at the belt while the vacuum is in the upright and locked position, the belt will be loose. The idler removes tension so the brush doesn't spin while you walk away and put heat marks in the carpet. Hit the lever that allows you to move the handle low, like you are vacuuming under the bed, and the belt gets tight.
Posted on Feb 01, 2013
Make sure brush setting is ON (carpet) not OFF (floor)
Posted on Jan 19, 2013
  • 134 Answers
Hi
There is no tension adjustment.
Id say you uswed the wrong belt. Hoover have many many sizes of belt. Check with your dealer
Rob
Posted on May 25, 2009
2 Suggested Answers
  • 272 Answers
SOURCE: New Hoover belt nbr 385280-34 installed, belt still too loose.
There is no adjustment. As they wear they cut the groove in the roller deeper. Sure fix,and what Hoover will tell you to do is to replace the roller. If your like me though that isn't any good. so what I did was wind wax coated dental floss into the groove that the belt rides in and in and then put a couple of drops of super glue to hold the end and it works like a charm. Don't put too much in there the belt has to have a groove to ride in.
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
The brush does not move when turned on. The model number is UH70015. The belt appears loose.
There are two belts on this machine. The belt on the brush roller will appear loose when in upright locked position. Releasing the handle to an in use position releases a spring loaded idler pulley which increases tension on the brush roll driving belt. Check whether pwr on/off button flashes when attempting to turn on. This may indicate an obstruction or faulty sensor.
Feb 22, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
How is the V-belt tension adjusted (Hoover Model U6439-900)or how do I know if the tension is correct? There seems to be a lot of "play" in the belt and I'm wondering if that is the reason the brush roll...
The V-Belt is not adjustable. There are two ways the belt has no tension: (1) when the handle is upright, a mechanical lever takes the drive tension off the belt, and (2) the brush roll lever setting you described. The upper handle would have to be in the floor cleaning position to check the belt, not in the storage position.
Oct 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
My Hoover U6439-900 also losing belts
When upside down there is no resistance,on carpet there is.
You need to try a a fresh, genuine hoover belt and buy a spare, belts stretch and slip after 30 -90 a days of normal use, often to 25-30% oversize Hoover belts generally fit very snug. If your belt looks shiny inside, that is likely the issue. Try that and post results
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Beater Bar Belt loose and bar won't turn
Provided that the motor isn't loose, the belt should fit tightly. If you had reassembled the beater bar back in the vacuum improperly, the belt would be tighter, rather than looser. If you are sure that the motor isn't loose and the beater bar was reinstalled correctly, then either tha belt slipped back off the motor shaft, or they sold you the wrong replacement belt.
Jul 18, 2009 | Hoover U6630-900 WindTunnel Bagless...
May 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
669 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
