Cars & Trucks Logo
D
Diana Grabowski Posted on Jan 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Inside condensation on my windows in my 2009 Volkswagen EOS
Jamie Heppner
Level 2:
  • Expert 111 Answers
  • Posted on Jan 08, 2014
Jamie Heppner
Expert
Level 2:
Answers
111
Questions
0
Helped
47427
Points
341
Normal at this time of year. You can buy a moisture kit from an auto parts store, or at a Walmart or similar type store. If you don't want to do that, wait till a sunny day and park the car in the sun with the windows cracked. It will help dry out the inside.
3 Related Answers
Anonymous
  • 70 Answers
  • Posted on Nov 30, 2009
SOURCE: Uneven rear wheel tyre wear on Volkswagen Eos
Be sure that the screws that hold the wheel are firmly an uniformly screwed. Check if on the both sides you've got the same problem.
Anonymous
  • 74 Answers
  • Posted on Jun 16, 2011
SOURCE: Volkswagen EOS yellow light appeared
Check front and rear brake pads.Don.t add brake fluid before changing the brake pads.Check the level after that.
maaaartin
  • 561 Answers
  • Posted on Jan 01, 2010
SOURCE: my volkswagen eos is getting wet on the inside
possibly suspect that the air conditioning is not working, if you get into your car in wet or humid weather and the windows steam up, put on the AC, if they do not clear then it could be that there is a filter blockage or drainage blockage on your AC or it is defective. again get it checked by a dealer or AC specialist.
2answers
Does a 2009 Volkswagen EOS have an OBD two computer
http://www.outilsobdfacile.com/location-plug-connector-obd/Volkswagen-eos-1
I have an EOS VW 2009 and it had 5 window switches in the driver side door to the front windows and back windows and a switch to push all four windows down/up at the same time. But right now my passenger...
Hi Kimberli,
I suspect that since all windows can be powered up and down, you have issues with I believe 2 specific switches you mentioned that have problems - as a result of possible rain water, melting snow / ice or spillage of beverages. You might be able to clean them up - or replace the ones that are "flaky"
Battery removal 2009 vw eos ?
Hi. Ther is a bolt and plate at the base of the battery holing it in. 13mm socket and extension will be needed. Good luck.
Condensation and ice build up inside my 2009 Volkswagen EOS
CHECK FOR WATER INSERTING INSID CABIN.IF OK LET ME KNOW
Throttle position sensor 2009 eos
Hi. I presume you are talking about the one at the pedal. If so then take of the size 10 or 13 plastic nut on the side. Then you need 2 long thin screwdrivers and you will find 2 slots on the base, against the carpet, insert and release the internal clips. it is best to see the new one and look how the clips work. unplug and refit by pushing the new one into place. Kind regards, Neil
Where is the battery in my 2009 Eos?
VW Eos battery is placed in the engine compartment.
Can one ajust the window settings to open & close with remote.
NO this can not be done on models before 2009 and im not sure if it can on later models either. but what can be done is as follows
if you insert your key into the door lock from the outside you can open and close the windows. you may have to turn it to the lock position and then unlock and hold the key in this positoin until the windows open .
in the manual it also states that if the roof is down by turning the key in the door lock to the lock position will also close the roof the sunroof along with the windows.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
