We want to change the the old code number and enter a new number.
I would like to know how we can do this.
if you look on top of the unit, you should see a small screw - remove that screw. now you will need a small stiff wire, punch in your original code and then take the wire and push down through the hole ( this will reset wheel pack ) -- now punch in your new code and then rotate door handle to the right. now try your new code several times to make sure it took and that should be it.
now I have seen some of these units that do not have the access hole in the top -- if this is the case then you will need to access the reset button from the back of the unit -- remove the lock from the door, now look at the back plate -- you should see 6 small philip head screws -- remove those screws and remove the plate. now look at the middle of the unit - you should see a long rectangular box unit ( this is the combo pack ), now on the top of the combo pack you will see a small lever, now from the front of the unit - press in your old code, turn the unit around and with a flat blade screw driver push down that little lever,, now push in your new code,, rotate the door handle to the right ,, test your new code several times and re-install unit,, and you are done.
c...
