Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
New Hoover belt nbr 385280-34 installed, belt still too loose.
My Hoover upright vacuum, model U6476-900, has a front agiator belt that is loose and slips on the agiator so it will not turn under a load. I replaced the beld, 385280-34, but its the same problem, too loose. Is there a tension adjustment on the tension roller? How is this tension problem corrected?
    President:
  • 272 Answers
There is no adjustment. As they wear they cut the groove in the roller deeper. Sure fix,and what Hoover will tell you to do is to replace the roller. If your like me though that isn't any good. so what I did was wind wax coated dental floss into the groove that the belt rides in and in and then put a couple of drops of super glue to hold the end and it works like a charm. Don't put too much in there the belt has to have a groove to ride in.
Posted on May 25, 2009
Hoover Tempo Widepath - propellor not working
If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
May 02, 2010 | Hoover Tempo Widepath Upright Vacuum -...
I just replaced my hoover belt and it is too loose to make the brush spin. Is there an adjustment to tighten the belt
Greetings from GoVacuum,
The belt is going to be loose as long as the vacuum cleaner is in the upright posistion. If you have the vacuum cleaner with the handle locked in the upright setting, then the belt will be tight around the skinny belt. Once you release the handle of the vacuum cleaner, you can watch as the belt tightens over the roller brush. There are numerous problems with this particular model. We have recorded a very helpful video review of how to replace the belt, and do basic maintenace for this particular model. Hopefully this will help you figure out the correct installation, and other maintenance work you can do yourself.
Here's the video;
If this still does not fix the problem, and the brush is still not spinning, please feel free to email me at chris.jones (at) govacuum.com. I'm always more then happy to try and help you fix the vacuum.
If this information helped you, please click the rate this solution by clicking the thumbs up icons in the right hand corner of this solution.
Thank you very much,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt tension adjustment
If you are looking at the belt while the vacuum is in the upright and locked position, the belt will be loose. The idler removes tension so the brush doesn't spin while you walk away and put heat marks in the carpet. Hit the lever that allows you to move the handle low, like you are vacuuming under the bed, and the belt gets tight.
May 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Loose paint is stuck in my Hoover 5753-900. Now it won't turn on
Take the bottom plate off where you would install a new belt. the impeller is clogged up. use a wire to poke out the clogs. you can use a shop vac to **** out the debris. check your belt for wear spots while your at it. you may need a new one . befor removing the belt. make sure you notice in what direction it is installed. If you put it on backwards you brush will turn in the wrong direction,not good. draw a picture if need be. Ok good luck DFD
Apr 11, 2009 | Hoover U5753-900 WindTunnel Bagless...
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover very noisy after new belt installed.
what is the belt # you have installed (generic)? Yes, there are problems with using generic belts on Hoover Vacuums. If you have noise I would suspect the roller, and replace it. the cost is about $25 and is something that you can install. The newer type are mande of wood and are very quiet.
Nov 23, 2008 | Hoover U5753-900 WindTunnel Bagless...
Installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
BELT TO THE BRUSH SEEMS TOO LOOSE EVEN WHEN REPLACED
Hoover U6437-900 U6439-900 Upright
LOOSE BELT. THE BELT IS STILL LOOSE EVEN AFTER REPLACING
The reason it seems like the belt is too big is probable correct, you may have the wrong size belt for your vacuum, use genuine belts – your particular model is a self propelled model and takes two (2) belts and they should stretch on very tightly and snug and it is smart to use the genuine belt package for the model that you have and we Recommended the belt change for flat belt(s) are 4 to 6 months for better cleaning
They should be tight on the belt pulleys in order to do the best cleaning – use genuine belts
Telephone
8 a.m. - 7 p.m. EST
Apr 03, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
210 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
