Unable to turn on aircon with remote control and no manaul on button on the air con unit
Need help on my sanyo window air con unit, model SAC-88G. Unit cannot be power on with the remote control and there is no on button on the unit, kindly advise, thank you.
  • chiawm02 May 25, 2009
    - Battery is new and remote is working fine with displaying showing all information.
    - A/C power and fuse breaker is OK.
    - The same problem also happened during the first year of use. Sanyo service personnel attending to my call replaced one of the board during their visit. Was however not present and not sure the root cause to the problem.
  • stonedcrab May 11, 2010
    Have you changed the battery on the remote?
    Is the A/C plugged in properly and the fuse/breaker OK?
  • 10,865 Answers
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
Posted on May 25, 2009
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
Need a conia airconditer remote control here in Australia. We have 2 split systems that use the same remote. Models CA 24003 & CA 3003. Conia have gone bust here and we can't get a replacement remote....
i had the same problem and i managed to find a universal remote control from JARCAR Electronics. Model of the remote: Digitech AR-1729. It doesn't list Conia as compatible but I managed to gain control of the aircon using the code: 291. For some reason when you press the power button on the remote, it's like your double pressing the on button so the aircon switches on and off quickly. You need to press the power button on the remote quickly and move it from reception before it powers down the unit again. At least I have control of the aircon again and I don't have to put up with these humid hot days in melbourne... Good Luck.
Jan 01, 2010 | Heating & Cooling
KELVINATOR AIR CON
More than likely it is the remote sensor in the indoor unit. Then again I presume that it is the correct remote control. Sometimes a remote for one aircon may not communicate with another aircon even if they are the same brand.
Jan 24, 2009 | Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
We have lg air con, i think it is a split system. no buttons visiable. we lost the remote for it a while ago. it turned itself on an hour ago. cannot find remote want to know how to turn off?!
Find the circuit breaker of this aircon outlet or unplug the unit to outlet or wall socket to made it off. If your desire and want to shut it down.
Then final option, Find the Thermostat control (Temperature control) If its digital theres a small lcd show the number and figures that control the temperature set up to start and off the unit.
It can be done by remote only.
On the other manual way you must find also the knob and rotate it clockwise to increase the temp and run longer.If reverse counterclockwise it decrease the temp. and turn it off quickly as possible. In case if it compose of slide control. Upward to increase and downward to decrease
All aircon unit has its panel board or LCD Screen that control the power on & off.
You can test the result by trying to put a power again on the unit.
I hope you you find my solution successfull. Until you locate and found the remote.
r_ic7
Nov 27, 2008 | Coleman Mach III Air Conditioner
My LG plasma gold ac's remote controler
If you lift the flap on your indoor air con there is a Emergency operation button on your right you can operate the aircon from there. Push once for 20 cooling and twice for 22 heating
But sounds like you need a new remote. If you want to know how to test the remote please let me know
Hope that helps
Nov 16, 2008 | LG LS-L1210CL Mini Split Air Conditioner
2001 Audi A6 air con
The econ button allows you to set the heating manually, With this button pressed only manual heating is on and aircon is off.if you want heating and aircon off press the OFFbutton
Jul 01, 2008 | 2001 Audi A6
Timer set on remote, cancels out after use
I have discovered that a 7 day timer is available, but it is a fixed and separate box and will need to be programmed into the wall unit, at a cost of $500.As i am a pensioner and unable to afford this cost, I must persevere with the remote I have. Why can't the so-called experts provide a top of the line product in the first place?The last aircon unit I had was a Fujitsu, and that DID Have a very good remote enabling a programme of ON - OFF, On - Off in a 24 hour period. Thanks for trying to help.
Apr 21, 2008 | Heating & Cooling
Heating & Cooling Logo
532 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
