Question about Hotpoint RB757 Electric Kitchen Range
Self cleaning hotpoint stove
Hi, I cut on the self cleaning element on my stove , and once oven is clean the stove 's oven don't come back on . What should I do.
  • Anonymous Mar 29, 2014
    electric stove
  • 473 Answers
Sometimes in self clean it can burn out the element.  Need to check the element with an ohm meter and see if it shows resistance.  If it shows open then the element is bad.  If it shows resistance then the element is ok.  Next see if you are getting 220 volts to the element when in bake mode.  If you are not getting 220 volts then the control is bad.
Posted on Oct 21, 2007
I put the oven on and after about 10 minutes I get a message on the stove with beeping saying F2
At the back of the oven the sensor wire connects to the erc wireing via a plug, cut out that plug, and hard wire the ends together, frequently that plugs connection is not tight enough, and will result in F2, if that does not fix it, replace the sensor.
Read more:
Apr 20, 2016 | Hotpoint Kitchen Ranges
My older model electric hotpoint selfcleaing range, lower oven self cleaning function is not working. what could be wrong, maybe i didn't set a control knob correctly, don't have a maual for t
Back to the fifties! If the lower oven cooks normally, the heating element probably is OK. For self cleaning the normal temperature setting is bypassed and the heating element is set to a substantially higher level. Your oven may be unable to self clean because operation of the knob may not actually start the cycle. The thermostat could need replacing even though normal cooking is OK.
Sep 02, 2012 | Hotpoint Kitchen Ranges
After self cleaning not heat up
There is most likely a thermal fuse in the back of the oven. When this blows it cuts the power to the elements. This is very comon after self cleaning. Take the back off the stove, locate the fuse and check for continuity. (Turn off Power) Hope this helps. Google search thermal fuse for your brand of oven to get an idea of what the part looks like.
Apr 23, 2012 | Refrigerators
The self cleaning oven cuts off before cleaning cycle. I push the self clean button after locking the oven door: the bell dings several times and the self clean cycle cuts off. This is a new stove--what...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | GE Spectra JBP78 Electric Kitchen Range
On my hotpoint stove the self cleaning light flashes when I try to turn my oven on the bake in it.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 05, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
How to use the self cleaning feature for the oven
That is probably a good thing... that feature causes many problems...
Check out this tip that I wrote...
Mar 30, 2010 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint self cleaning oven won't heat
maybe a bad connection with the heating element. Check to make sure bottom element is pluged in all the way. May need to be replaced if anything looks strange (ie. burnt spot, hole, srrange color, or maybe no external sign)
Aug 15, 2009 | General Electric Stove/Oven/Range Chrome...
Frigidair Gallery self cleaning stove
Hey charles
This often happens after you have gone through a cleaning cycle. In most cases the relay contacts has been welded shut to one side or burnt off. The relay can be replaced or the contact freed. Otherwise the controller (clock) has to be replaced (easier).
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Hotpoint RB757 Electric Kitchen Range Logo
652 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
