Question about Hotpoint RB757 Electric Kitchen Range
Have jenn air (not sure of model #) in house built in early 70's.
Drop in stove top cartridges are numbered 87946 or 87947 with statement they are only to be used with Jennair range, 2800W, 240V. The wiring, with cloth insulation, is breaking down. I am confident of my ability and would like to rewire the two drop-in cartridges. What gauge wire should I use and is it okay to use plastic insulated wire rather than the cloth insulation (can the cloth insulated wire even be found anymore)? Thanks for the help.
  • Hotpoint Master
  • 2,005 Answers
Use at least #12 take a sample with you to the wire supplier (not a hardware store) you must purchase the heat protected plastic special wire (UL hi-heat) and, use porcelain wirenuts to make any wire-to-wire connections
Posted on May 25, 2009
I am looking for a plug in electric unit for a 1980 Jennaire counter top stove.
if your looking the cartridge that fits in and has burners the cartridge has its own model number which can be found on the underside of the cartridge
Aug 13, 2011 | Jenn-Air JES9860 Electric Kitchen Range
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
My glass surface broke on my Jenn Air stove, and I'm having problems finding a replacement part.
if you get me the information i will find you the top but they arent cheep ! you may want to look for used parts ?
Stove model
serial number
any other info you can find on it thanks Frank
Sep 24, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Nov 23, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Stove top burners
It is not the cartridge. It is the ignition switch (sometimes called a cooktop switch) I found mine on ebay. In particular it is a faulty rear switch. Save your money on the cartridge.
Feb 10, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Hotpoint RB757 Electric Kitchen Range Logo
353 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
