Question about Epson Stylus CX8300 Printer
EPSON CX8300 (CANNOT RECOGNIZE INK CARTRIDGES )
  • 3,866 Answers
Print head needs to be cleaned or replaced, this needs to be done professioanly if you not sure how to do it/
Posted on May 25, 2009
Epson ink cartridges, always empty?
Epson has gone to great pains to ensure that third-party cartridges dont work. They really did a good job. Sometimes their printers wont even recognize genuine Epson cartridges. I saw a CX8400 with a brand new cartridge claim it was out of cyan ink after printing one 4 x 6 photo. Then it would recognize any cyan cartridge. It had to go back to Epson for replacement. Sign in China com Online Wholesale for AD Signage Product
Apr 22, 2014 | Office Equipment & Supplies
Tip
How To Reset Ink Counter On An Epson CX7300, CX8300 or CX9300
You must set the date in your computer to "April 11, 2008" to run Resetter Epson CX7300, Epson CX8300 and Epson CX9300 without error. If do not alter the setting of date of according to rule then software will deleted automatically when running.<br /><br />If you have an error, delete all following entry before you rerun the software.<br /><br />delete registry key: <span style="font-weight: bold;">HKEY_LOCAL_MACHINE\SOFTWARE\EPSON\PTSG</span><br /><br />and delete folder: <span style="font-weight: bold;">C:\adjustment program</span><br /><br />To reset waste ink pad counter Epson CX7300, CX8300 and CX9300F use adjustment program. I have tried this software and this software worked. To run this software without error please follow the instructions above.<br /><br />Here How to use this software:<br /> <ol> <li>Download the adjustment program (see below)</li> <li>Extract the file you have downloaded</li> <li>Go to The extracted folder then click tricks-collections.bat file</li> <li>Now set the date setting in you PC to 11 April 2008,</li> <li>Run adjustment program by click AdjProg.exe file the click accept</li> <li>Click Particular adjustment mode then select destination and printer port then click OK</li> <li>Select Waste ink pad counter from the below window and double-click to execute it</li> <li>Click [Check] button to check current protection counter's value.</li> <li>Then Click [Initialization] to reset the protection counter to the initial value.</li> <li>After finishing, you can change the date back to normal.</li></ol><b><br />Link Adjustment program for Epson CX7300, CX8300 and CX9300F</b> <ul> <li> Adjustment program for epson CX7300: <a href="http://www.mediafire.com/?8wrkugah2mj">http://www.mediafire.com/?8wrkugah2mj</a></li> <li> Adjustment program for epson CX8300: <a href="http://www.mediafire.com/?0xfnrgarvuj">http://www.mediafire.com/?0xfnrgarvuj</a></li> <li> Adjustment program for epson CX9300F: <a href="http://www.mediafire.com/?o020wlaf6te">http://www.mediafire.com/?o020wlaf6te</a></li></ul> <br />
on Mar 09, 2011 | Office Equipment & Supplies
Can i print documents using black ink only when other inks are empty?
All the ink cartridges need to have ink in them to allow you to print, even if you only want to print in black only.
Oct 14, 2012 | Epson Stylus CX8300 Printer
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
How do you replace ink
You can find complete instructions on what cartridges to order and how to install them at this link.
Mar 09, 2011 | Epson Stylus CX8300 Printer
My epson cx8300 prints a pink instead of a yellow color and a green instead opf a violet one. how do i adjust this?
I think your printer head is block. If yes
#clean printer head by using hot water or alcohol.
and another regon is your printer ink cartrige / refill ink may be alternet. if yeas
#set the cartrige or ink properly.
Thank's
Feb 09, 2011 | Epson Stylus CX8300 Printer
My Epson 105 doesn't recognize my Epson 88 ink cartridges
please use only recommended cartridges found either on the upper portion of your printer or in the printer manuals.... take note of the code.
Jan 28, 2010 | Epson Stylus NX105 All-In-One Printer
I refill my epson C60 cartridges and have a chip resetter. Now, the cartridges won't release ink when printing. I get a blank page. The printer recognizes the cartridges. What is causing the blank page?
Put the ink cartridge onto a damp paper towel.
Does ink "bleed" onto the paper towel?
If not, then the print-heads are clogged,
and you should run the "head-cleaning" software (part of the software package for the Epson printer).
Dec 30, 2009 | Epson Stylus CX8300 Printer
My cx8300 saw waste ink pad in printer is suturated contact the dealer to replace it!how can i solve the problem!!thanks!!
i get start the printer Epsom printer cx8300,cx8400 and viw the error wast ink bad bad no run how ripper that
Apr 23, 2009 | Epson Stylus CX8300 Printer
Epson Stylus CX8300 Printer Logo
724 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
