Question about HP DeskJet 3940 InkJet Photo Printer
The printer doesnt recognize paper
It tells me that it has no paper when it really has, so it doesnt try to print anything
    President:
  • HP Master
  • 990 Answers
HEllo sir; On the paper tray there have a paper senser, is out off track or defective.
Posted on May 25, 2009
Printer recognizes tray 2 but will not print from tray 2.
its not reading there is any paper in the slot so will not load from this draw. the is a switch that when paper is installed it lifts it to tell printer paper loaded. like any switch they can fail.
Jul 03, 2017 | Lexmark T630 Laser Printer
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
My Ricoh Aficio printer 1018 is telling me to "load paper 8 1/2 * 11" on the screen whenever i try to print anything from any computer in the network because i am using RJ 45 instead of normal...
Make sure you have 8.5" x 11" paper loaded into at least one of the paper trays, and make sure it's loaded in the same orientation as the page you are trying to print. Also check to be sure the copier is set to recognize 8.5" x 11" paper -- it may be set for a different size. On the main Copy screen, if you select the paper tray, does it show 8.5" x 11"?
Feb 03, 2011 | Ricoh Aficio 1018 Printer
Wont Print
try to go under control Panel - Administrative Tools - Services, then scroll down to Print Spooler and stop the service, then restart it. Try to print now.
good luck
Mar 31, 2009 | HP Officejet J5780 All-In-One Printer
Recognizes printer, won't print
What i'm getting at is if the printer was not used for a long time the cartridges may have dried out.
Robert
Aug 30, 2008 | HP Photosmart 8250 InkJet Printer
Not printing
cancel all the pending documents pending in the print queue.then try
Aug 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Original Loaded
I just came across this very same problem today on my L7580 and I found that there is a spring loaded bar that flips down and makes a contact. When paper is inserted it lifts this bar up and tell the feeder that there is a document. If this is stuck in the upright position then you will always have the "original loaded" message and have your issue. Mine had popped out of its alignment holes and I had to snap it in and the whole thing worked like a charm!!! I hope this helps everyone else with this issue!!!
Jason Gray
Jul 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Helpp
Are you sure that all the paper came out? I don't really know anything specific about your partic- ular printer; but if any paper is still in the paper path, it may not allow itself to power on. Can you see that the paper path is clear all the way through from pickup to finish? Do you have a user's manual with the printer? You may be able to perform some sequence of steps to clear the nvram on the printer if necesary. If still no power, investigate power connection, try alternate source (other outlet, power strip). Also, alternate power cord for printer if possible. Good-luck:)
May 28, 2007 | HP Photosmart 7450 InkJet Printer
HP DeskJet 3940 InkJet Photo Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
