Question about KitchenAid KEYS700LQ Electric Dryer
Checked the fuse it's ok but the dryer still won't start
I have a kitchen Aid model# ykeys677eqo I have checked the fuse for continuity it good what should I check for next. thanks Westam
  • Anonymous May 25, 2009
    The machine is not running,the thermal fuse has been changed still won't run, should my next step to change the timmer?
  • 10,865 Answers
Hi Westam - It sounds like you are a pretty mechanical guy so let me quickly list and briefly explain all of the possible reasons why your dryer won't work. I hope you will then be able to isolate the problem and fix it. Let me know if you need more information
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on May 25, 2009
    President:
  • 1,136 Answers
Hi, What kind of problem are you having? Heating or running?
I can help.
Vic
Blown fuse jed8430adb
I would like to assist you but I am confused as too your model and fuse you refereed too. Is this a Kitchen-Aid or a Jen-air model?
Where is this fuse located? If I remember correctly in the Kitchen-aid model there was a single unit that had fuses with the harness and not on the lookup when you seek parts. But without more information I don't want to lead you down a goose chase.
Get back to me and I will be glad to help.
Thanks
Oct 14, 2013 | KitchenAid 36 in. KECC568GSS Electric...
Kitchen aid microwave will not heat
first check the fuse if cutoff, replace it. if ok, then check for any broken wire. if all connections are intact, then test the heating element for continuity, if no continuity, then the element is bad and needs replacement. try these steps
Jun 11, 2013 | Microwave Ovens
Kitchen Aid dishwasher has no power. outlet has power. Is there a fuse or breaker that we can reset? Type:577-0 Mod:KUDP01FLSS5 SER:FR3005854
Welcome to FixYa.
Based on your brief description, I'd suggest you likely have a faulty thermal fuse in the control board as you alluded to, but it is not resettable unfortunately.
It's pretty easy to replace or to check, I've attached a link below to change the fuse, but you can also use the link to access the thermal fuse to check it.
With the aid of an ohm meter, remove one wire and measure across the two contacts and it should show continuity, otherwise it's open and therefore no good.
The part is available at most brick & mortar part places or on-line at vendors such as "repairclinic.com" or searspartsdirect.com" to name a couple. Part number 8193762...looks like this image and retails for about $15-$20USD based on the model you provided.
This is the youtube link to help with the repair "how to".
http://www.youtube.com/watch?v=jdlVbTXm8SY&feature=player_embedded
Let me know how you make out or if you require any further assistance and I'll try to help in any manner I can. Good luck.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Apr 17, 2011 | KitchenAid Dishwashers
Kitchen Aid Electric Dryer Model # KEYE678BALO, won't start.
This is most often caused by a bad thermal fuse or thermostat high limit cutout. Check them for continuity (with the machine unplugged, of course) They should have continuity -- replace them if open. They should be available at www.appliancepartspros.com Also, if one or both are bad, check the dryer vent as they often are damaged by high heat due to a restricted vent pipe. The website above also has diagrams to help find the parts on the machine.
Dec 30, 2009 | Washing Machines
Tried to run dishwasher but it wouldn't turn on -
If you have no power and no lights at all,you may have blown the fuse. There is a non-resettable fuse in the top right corner of the control board.Remove the 6 screws across the top of the console panel to access the board and fuse.
You can check the fuse for continuity with a meter set for ohms or continuity. Al;so check the door switch below the open/close lever for continuity.Check incoming power under the dishwasher were the incoming power wires connect.
Dec 26, 2009 | KitchenAid Dishwashers
Kitchen-Aid Dryer has power to dryer , door switch is working ,and inside light is working but dryer will not start.
Check for a blown thermal fuse. It's about an inch long and is inside the rear of the dryer, usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Sep 11, 2009 | KitchenAid Dryers
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
After self cleaning cycle on my Kitchen Aid kgsa 906, was finished the door opened, but the next morning the door wouldn't open and the control panel was blank
You may be experiencing the dreaded Thermal Fuse overload problem.. search the other posts, i've included easy steps to replacing it..
(you may want to check yours for continuity with a radio shack tester before you buy a new one)..
good luck
tpug
May 09, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen aid range heats up too slowly
Take the element out and check the ohms on the element. Replacing the element will fix you up.
Nov 16, 2008 | Kitchen Ranges
Kitchen Aid KGRC608
Hi does this range have a fuse for the circuit/timer board its not on at all but burners still lite and starter works if the is a fuse will you tell me where its at or is the top board fryed or the bottom board yes there is a bottom board on the right sie base in draw area dont know what to change i thought maybe it was only a fuse but can't locate it thanks for your help with this . model kgrc608lss0
Jul 30, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KEYS700LQ Electric Dryer Logo
186 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
