Question about Bose 3 2 1 GSX System
Dvd player always says "no disc " when i play it...ed...
I have a bose 321 system. dvd player won't play if i play it, it always says " no disc"... ed...
    President:
  • Bose Master
  • 1,114 Answers
First try running a CD/DVD player cleaner disc thru the unit, you can find them at Walmart, Target, etc. Get one that uses fluid. If your lucky, it's just dusty and needed cleaned. If it's still inoperative, you need to send it to Bose for service. They will swap out the transport for a new one and you will get many more years of service out of it. Just occasionally clean it. The repair will probably run 100-150. You can call Bose support for average pricing for transport repair and they should give you at least a ball park estimate. Hope this helps
Posted on May 25, 2009
Sony DVD+R AccuCORE disc recorded on HP dv4-2045dx laptop notebook will not play on Bose 321 system Get disc incompatible message What can I do?
Sometimes dvd players will have problems playing certain types of recordable discs. You might need to switch from the Sony brand and try a different one. Also there are DVD+R and DVD-R types. The Bose might have issues trying to play a "+" type disc. Also make sure that the disc is being properly "finalized" by the burning software you are using so the Bose system will recognize the disc. The burning software I use is called Nero Burning Rom and it is very easy to use. It allows you to control the burning for various applications and can help with "problem discs". If you are able to play other burnable discs in the Bose and the Sony discs are the only one giving you the problems then it is probably just that brand and you will not be able to use them with your Bose. And just a note some older DVD burners can only burn "+" type discs or "-" type discs but not both. Your computer according to the specifications from HP should not have a problem burning both types as long as the drive is the original.
Mar 07, 2010 | Bose 3 2 1 GSX System
I have a friend with a 321 system. He says it
Unfortunatley no, its not software that reads dual layer discs, its hardware. I sold Bose for 2 years and do not know of any Bose items that will read dual-alyer discs. Dr. Bose has a hard time keeping up with technology sometimes. Other than that, the 321 is a great system!
Oct 02, 2009 | Bose 3 2 1 GSX System
When I press the Eject Button on the Bose 321 DVD Player the tray does not open up. I can hear the sound as if trying to open
normal issues with cd/dvd trays - gear/rubber of the tray transport worn out.
manytimes it helps if you always keep a cd/dvd in the tray (don't keep the tray empty)
it may also help if you can keep the bose 321 vertical.
May 30, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Everytime i play dvd player it always says "no disc"
The first thing to try would be to clean the unit. If you don't have a DVD player cleaner you can get them at Walmart, Target, or any electronics store. Get one that uses fluid. run it thru a couple times and hopefully all will be well. If not, you need to send it out for service. They will just replace the transport. Generally at a cost of 100 to 150 and two weeks or so for turn around time. Hope this helps
May 25, 2009 | Bose 3 2 1 GSX System
Burned dvds wont play on home player
i have begun having a problem with my  4-5 year old bose 321 system.  sometimes dvd's burned on my computer will not  play on my bose 321 system.  sometimes they will.  what's up with this?  it's not a bad media problem.  i've narrowed it to the player.  sometimes i'll play a computer burned dvd on the bose and it will play fine.   next time i try to  play it it won't any ideas? thank you in advance mike
Dec 04, 2008 | Televison & Video
Bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
Nov 27, 2008 | Bose 3 2 1 GSX System
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
Can't read the disc !!
I replayced dvd cd-rom myself it's very simple repair and it cost me $20.00 for new dvd rom. Don't buy CD-RW but just simple black dvd-rom.
I hope this will get you going again.
Jan 28, 2008 | Bose (321GS) System
Problem with my Bose 321
I had the same problem listed; send an email to BOSE tech support - they sent me a DVD with a bios upgrade and it fixed the problem. They should put the BIOS upgrade on their website so you could burn your own DVD rather than waiting for the mail. But it did fix the problem. Netflix disks were the worst; they must do something when they burn them to get that forced Ad to play that Bose doesn't like.
Dec 20, 2007 | Bose (321GS) System
Bose 321 DVD System
I love my Bose 321 DVD system, but a few days ago, it started acting weird. I put in a DVD, and it reads - "No Disc".....and I'm not sure why. I cleaned the disc, and I also played a DVD/CD Maintenance kit - I'm not sure what is wrong. It seems like I have a problem within the system - what can I do?
Dec 10, 2007 | Bose (321GS) System
Bose 3 2 1 GSX System Logo
250 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
