Question about RCA R52WH76 Television
How to adjust pitcher size
How do i adjust the pitcher on the tv it is cutting the heads off on all shows on a rca r52wh76
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
Posted on Jun 14, 2009
Where is the convergence fuse located on a RCA M# R52WH76
Right to the right side of the flyback. You will see three small brown rectangle ( fuses) FL221, FL231 and FL251 the center fuse is the FL231 which is the fuse for convergence. I am posting a pic of where its located.slinteriors_14.jpg
Jul 20, 2011 | RCA R52WH76 Television
My tv is a rca r52wh76 tv and it keeps popping on and off the menu, the input keeps changing and the sound keeps going down to no sound
did u check the remote? i mean remove the batteries of the remote and remove the tv from electricity and put it back on the tv but not the remote batteries and check if it works normal and if it does buy a new remote.
Nov 21, 2010 | RCA Televison & Video
Rca hdtv rear projectiontv.how to adjust focus
You will want to use a funtion called either convergence or auto convergence. It realigns the 3 colors to the correct possition on the screen.
Feb 28, 2010 | RCA R52WH76 Television
Digilogic tvcombo keeps cutting out
probably got a bad capacitor in power supply
Sep 07, 2009 | RCA R52WH76 Television
RCA TV from 1989 will play VCR
check rca jack maybe some wire cut. check also vcr head maybe dirty.
May 30, 2009 | RCA F20TF10 20" TV
Can I hook up regular sterio speakers to RCA 52 digital HD TV
yes the itc has the option to hook external audo amp to the tv..
Apr 05, 2009 | RCA R52WH76 Television
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
Rca r52wh76
check out the fl231 problem under the tips and tricks section under my profile willtab. the fuses are small rectangular next to big black part called the flyback
Aug 03, 2008 | RCA R56WH76 Projection Television
Heads Cut Off
Is it in zoom 4:3 or zoom 16:9? Use the left/right arrows to change it.
May 06, 2007 | RCA D52W19 52" Rear Projection Television
RCA R52WH76 Television Logo
317 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
