Question about U.S. Robotics MAXg(USR9108) Wireless Router
Port Forwarding with Kaspersky Internet Security 2009
I am using Kaspersky Internet Security 2009. But it blocks all the forwarded ports of my router (usr 9108). Everything worked fine before I installed Kaspersky. I need to do port forwarding in order to use Bittorrent. Please help me. thank you.
  • llrajitha May 25, 2009
    actually there is nothing called "Anti Hacker" in KIS2009.
  • fougzki May 11, 2010
    Did you try to list the bit****** in kaspersky exception list if it have? Commonly it can be found in settings. allow the bit** to pass.
  • 34 Answers
Anti Hacker -> Settings -> Enable Firewall -> Low Security -> Settings ->
Rules For Applications -> Add -> Torrent
Edit Rules -> Add -> Rule Name -> utorrent
Properties -> Remote port (selected)
properties -> Local Port (selected)
Rule description -> Remote Port - >(enter the port) -> DEPENDS YOUR CONFIG
Rule description -> Local Port - >(enter the port) -> DEPENDS YOUR CONFIG
Allow Inbound and Outbound TCP connection, where :
Remote Port: DEPENDS YOUR CONFIG
Local Port : DEPENDS YOUR CONFIG
Posted on May 25, 2009
How to Watch Security Cameras on the Internet (Port Forward IP Cameras)?
what sort of router is being used ?
are the cameras on static ip addresses ?
google search for
model of router and port forwarding
http://www.wikihow.com/Set-Up-Port-Forwarding-on-a-Router
Oct 19, 2016 | Cell Phones
Why can't I print on cloud print with my canon inkjet mp830. It keeps saying "printer offline"
Hi, you may find that opening port 5222 in your router settings corrects this for you. This is due to Google Cloud Print (GCP) needing to poll your printer, if the port is not open then GCP will not get a response from your printer, therefore will show it as offline.
It is also possible that your firewall is blocking communications so you would need to open the same port (5222) in your firewall / antivirus software.
Warning: Ports are often closed on a router to help prevent unauthorized access to your home network. Opening any additional ports on your router may decrease the overall security of your network.
  1. To use port forwarding first determine the local IP address of the computer or device you are forwarding the port to.
  2. Open your router configuration / settings menu.
  3. Once in the router configuration locate the port forwarding settings, often in a section such as Applications & Gaming or Port forwarding. I would suggest that if you are having difficulties with this to refer to your router documentation or call their support line.
  4. You will only need to open port 5222.
  5. Give your new rule a name that you will recognise.
  6. Next enter the port number 5222, if you are asked for Externet and Internet enter 5222 in both.
  7. The protocol is TCP.
  8. Next is the IP address of the computer.
  9. Don't forget to check the enabled box if there is one and save changes.
If you have any issues with this I would suggest Port Forward web site where specific instructions should be available for your router.
Tom
Jan 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
Port forwarding
Connect your Internet phone directly to the cable modem and see if you can use Internet phone directly through the modem.
If it works through the modem then it must be the issue with the port forwarding.
First get the port numbers from the phone manufacturer.
Open the setup page of the router and open those port numbers.
Jan 15, 2012 | Linksys Wireless-G WRT54G Router
BL-C131 port forwarding.
So you've configured port forwarding on the router. Do you have any anti-virus applications installed or have your set an exclusion in Windows firewall?
Feb 01, 2010 | Panasonic BL-C131 Network Camera
Port forwarding with DIR-625 (wireless environment)
Does your modem has a NAT too? if not then upgrade the firmware of the router that usually fix the problem, if not then ask your ISP and see if they are blocking the ports. have you tried connection without the router to see if that will work?
Sep 09, 2009 | D-Link DIR-625 (790069292637) Wireless...
Port forwarding in Kapsersky Internet Security 2009
check if kaspersky has any exeptions...then me the port an exeption...hope it helps
Aug 25, 2009 | U.S. Robotics MAXg(USR9108) Wireless...
Open a port through kaspersky internet security 2009 firewall
uninstall kaspersky
you may also have to install recovery if problem
ocurs again
Mar 20, 2009 | Kaspersky Labs Internet Security 2009 Full...
How To Make a DMZ
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding, as described in How is Port Forwarding Configured? However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RO318 Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 (MR314NA) Wireless Router
U.S. Robotics MAXg(USR9108) Wireless Router Logo
2,167 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Prashant M
Prashant M
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
