Question about Zenith Z27X22D 27" TV
NEED TO GET INTO SERVICE MENU AND KNOW WHAT ABBREVIATIONS OR FOR
Need to get into service menu for zenith 1997 27 in. Z27X22D
Occasionaly messages show up on the screen
Posted on Nov 15, 2010
How do you get into the service menu?
Do you have the remote? After looking at the manual which you can download here:
http://www.retrevo.com/support/Zenith-H20F50DT-TVs-manual/id/277ci168/t/2/
it seems all that is needed is to hit the menu button.
May 04, 2011 | Zenith H20F50DT TV
I have a blue shadow appearing on my zenith rear projection tv. I've tried the auto convergence option along with fine tuning and color adjustments and have had no success. Any idea what kind of part I...
Thank you for your quickly response.
Yes, is repairable your tv.
Need be replace STK 392-120 IC , two pieces. Plus possilbles resistors (burn), prices is variable , depend where are you located and depend labor on each shop. but, is around $285--$400.
Because after replace STK IC's, your tv need a lot work on service menu area ( is no customer menu setting, this is special section on eprom service menu.
I hope my information is good for you.
Appreciate any opinion from you
Thank you
Dec 05, 2009 | Zenith R57W46 57" Rear Projection...
Need to access service menu/mode
To access the Zenith service menu: Hold down the menu button on the remote control until the menu disappears. Then type in 9-8-7-6-enter. This should do the trick. Be careful what setting you change. I would recommend writing them down before you change any. Hope this helps.
Apr 30, 2009 | Zenith IQC50H95W 50" Rear Projection...
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Zenith h25w35dt
You need to go into the service menu and turn the ac power setting to off and read to see if you can get the channel to scan To enter service menu: hold down menu on remote until menu disapperar then type in 9-8-7-6 then enter. Continue as described
Jan 02, 2008 | Zenith Z27A11G 27" TV
Zenith Z27X22D Service Menu Codes needed
significant vertical overscan. It is such that it's impossible to read crawls and such at the bottom of the screen. I think this problem is a tv problem. it is due to vertical section. please change electrolytic capacitor in vertical output section. it will be ok. it is common problem can be fixed at home & very simple.
Oct 03, 2007 | Zenith Z27X22D 27" TV
Service menu instructions needed
service menu code is 9876, i think. and you can manually adjust the focus using network54's post on "blurry z27x22d".
Sep 16, 2007 | Zenith Z27X22D 27" TV
Picture is dark
Does not seem like a bad tube alone. Could also be that the Video output Transistors Supply Filter capacitor having dried out. It is a 100mfd 160V capacitor, which on replacement will improve the brightness of the immage. And yes, you could also try increasing the heater voltage (Filament Voltage)of the Pictuire tube, this will definitely increase brightness, but will reduce the life of the Picture tube. You gotta think - 10 year old TV, should I repair or exchange and get a new one???
Mar 03, 2007 | Zenith Z27X22D 27" TV
Televison & Video Logo
114 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
