Question about Linksys Wireless-G WRT54G Router
After power outage I Can't connect without bypassing router
I have a dsl modem that goes thru my router and to my computer via ethernet. had a power outage last night. I still can get online but only by disconnecting my router and going direct. All lights on the router are normal, I have powered down, reset, etc..
  • 34 Answers
If you can connect directly then, the problem is the wrt54g router. Possible problems:
1) Power Outage damaged the router
2) Power Outage reseted the router
For the second scenario, you should got to the browser and type: http://192.168.1.1/ and check whether you can enter or not. If not, you need to configure the gateway IP on your PC to 192.168.1.1
Posted on May 25, 2009
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
Jul 19, 2016 | TP-LINK Computers & Internet
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
CNet wireless router Model CWR-854V. is causing my Ethernet lite on my DSL modem to blink causing me not to be able to get on internet. Changed all cables no help disconnected Router and modem works...
Use an Ethernet cable to connect your computer directly to the DSL modem, bypassing the router, turn the modem off, turn the modem on, wait 60 seconds, and restart your computer.
Does the Ethernet lamp still blink when Windows is booting, and when you are using the Internet?
Turn the DSL modem off.
Turn the router off.
Turn the computer off.
Disconnect the Ethernet cable from the modem, and connect it from the computer to the router.
Turn the router on, and wait 60 seconds, then turn your computer on.
After Windows is running, click Start.
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: default gateway........ 192.168.123.456
If the string starts with '192.168', then your computer *IS* "talking" to the router.
Now, use an Ethernet cable to connect the WAN port on the router to the DSL modem.
Turn the modem on.
Turn the router on.
Wait 60 seconds.
Restart your computer, and you should be able to web-surf.
Jul 19, 2011 | Cnet CWR-854 Router
How do you set the router up!!! no diagram to hook up to desktop
How you connect it depends on how you plan to use it. Let me explain:
Some people have a dsl line (high speed internet connection) and their modem from their internet provider only has room for one computer cable to connect and use the internet. If the customer has more then one desktop computer they want to connect to the internet, they will need to buy a router. A router provides multiple ports for several computers to connect to the internet at the same time.
If you have a dsl modem already and bought a router to add additional computers to your network - then follow the instructions below to set it up:
Connect your phone cord from the wall into the dsl modem. Plug in the power cable from the dsl modem to the wall and turn it on. Connect an ethernet cable to the dsl modem (ethernet cables are the ones that look like a regular telephone cord but the ends are a little larger) and connect the other end to your router. Make sure you plug this cable into the port marked "ethernet" on your router. There is only one port for your internet connection line coming into the router, the rest of the ports are for adding computers only. Some routers say the word "ethernet" near the port for the internet connection. Others have a picture near or or brackets around it to show that it is different then the others. Plug in the power cord to your router and turn it on. Make sure you turn on your modem first and let it warm up before connecting your router. Modem power on first, then router power on - always.
Now connect an ethernet cable to your router and connect the other end to the pc you wish to use on the internet. Do not turn on your pc until the ethernet cord is attached. Your dsl modem has to be powered up first, followed by your router and then your pc. All in that order.
Your computer should automatically sense the internet connection upon start up. You can verify that your connection is installed correctly and that your pc is sensing it by looking at the bottom right side of your screen near the clock area. You should see a picture of a computer monitor that represents your internet connection status. Sometimes they glow green when they are healthy. Sometimes they show a red X on top of them if they are disconnected from the internet. If you can't find the Icon for your internet connection on the bottom right side of your screen, unplug the ethernet cable from the back of your pc - while watching the bottom right side area and plug it back in again. Watch for a change to locate the icon. Sometimes there is a downward pointing arrow near the clock which needs to be clicked on to open up the area and view the icons.
Thats all! One line from the modem to the router - another line from the router to the pc - and the internet should be up and running fine.
If you bought a router combination modem - then its the same as above - just without a separate dsl modem. (i.e. Connect the power cable from the router/modem to the wall. Connect the ethernet cable to the port marked "ethernet" for your internet connecton and connect the other end of the cord to your pc. Then turn your pc on. Router/modem power on first and pc power on second in that order)
All the lights on your modem should be green and steady - except for the one marked internet or connection which is usually flashing and moving. If you have any red or yellow lights then you need to troubleshoot and correct the problem before your internet connection will work.
Mar 03, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Wireless connection works fine from the d-link router but the desktop linked from the phoneline keeps going offline. Why?
    You've omitted some information about your hardware & configuration & connections.
    You should have:
    1. cable-modem connected to cable socket (or DSL-modem connected to telephone wall-jack);
    2. router connected via Ethernet cable to the cable-modem (or DSL-modem)
    3. desktop computer connected via Ethernet cable to the desktop computer
    4. wireless device (iPod or netbook or notebook) connected over the "ether" to the router -- this connection will stay "up" almost "forever" (as long as there is AC-power to the router and power to the wireless device).
    Which parts & connections do you have?
    Dec 26, 2009 | D-Link Computers & Internet
    I have switched to a Westell VersaLink 327W from a older Westell Wirespeed. The Wirespeed communicated via USB and the new Westell communicates via Ethernet. How do I get the computer to see the modem?
    If you are using a Westell DSL modem with ethernet connection, then you connect the modem's ethernet port to the computer's network card. This also uses an ethernet cable. Good Luck
    Jul 19, 2009 | Westell Wirespeed VersaLink...
    Internet connection
    Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
    Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
    Linksys Wireless-G WRT54G Router Logo
    258 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
