Question about Samsung LN-S3241D 32 in.LCD HDTV
Ghosting problems with a Samsung-LN32B360
Picture isnt as crisp as in the store and the channel info has a ghosting effect. The owners manuel blames cable box incapability.The use of component cables is supposed to solve this problem. What component cables are they talking about and where do these get hooked up? Or is this really the problem? I really could use so great advice before the wifes ready to take the tv back to the store.
    Sergeant:
    Champion:
  • 257 Answers
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
Posted on Aug 18, 2009
Picture brightness to high
If you do not have a copy of the manual, you can download it from here:
http://www.manualslib.com/download/472939/Samsung-Ln32b360-32-Lcd-Tv.html
You can adjust the picture brightness using the picture controls. Please refer to page 25 of the manual.
Apr 20, 2015 | Samsung LN32B360 32 in. LCD HDTV
LN32B360 no picture
does the display totally black or white screen then how about the sound still working.
Sep 07, 2012 | Samsung LN32B360 32 in. LCD HDTV
Samsung LN32B360 32-Inch 720p LCD No picture
Even though it is close out snd no return, it still should be covered by warranty, otherwise you will have to so some troubleshooting, but find out first from BEST BUY.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 25, 2010 | Samsung LN32B360 32 in. LCD HDTV
I have a five month old Samsung LN32B360 LCD TV I just turned in on and the picture came on but it had a rainbow look and then the picture goes off with sound only?
When you say 'rainbow look', do you mean vertical coloured lines on the screen? If so, then you will have a faulty Tcon. Could you get a snapshot of the fault and post it on here please then we can identify the problem more easily.
Apr 24, 2010 | Samsung LN32B360 32 in. LCD HDTV
Hey, i have a samsung ln32b360, just 2 months old. worked beautifully when i got it, but recently it started ghosting a little in very specific situations. then it started ghosting a lot, but only in dark...
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Rnj VINODKUMAR
Oct 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Screen has borders when watching tv
This is common issue of the channels that use 4:3 format while TV is designed for 16:9. To get it disappear, you just go to picture option, choose WIDE FIT, this fuction will widen the picture to whole screen. Of course, you have to accept the picture is blur a bit.
Aug 14, 2009 | Samsung LN32B360 32 in. LCD HDTV
KP-53S65 Blue Ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Sony KP-53S65 53" Rear Projection...
Samsung LN-S3241D 32 in.LCD  HDTV Logo
448 people viewed this question
Jerry Greenberg
Jerry Greenberg
