Question about Whirlpool LER5636P Electric Dryer
Dryer will not dry cloths
The dryer and it's flex hose is clear of lint but the dryer still will not dry cloths. This is the second hand me down dryer that I hooked up in the house and both don't dry cloths. Is there something with the electrical outlet?
    President:
  • 1,136 Answers
Hi, This an electric dryer or gas?
Do you get any heat at all?
Asking so I can assist you. Please let me know
Thanks
Vic
Posted on May 25, 2009
I have a problem with dryer not putting enough heat out to dry my clothes.The model #ler4634jq0.The Serial# ml3372706
this may be the result of a clogged vent hose ,Go outside and check the outside dryer vent they sometimes clog up with lint and as a result send false info to the sensor inside the dryer, make sure you clear any excess lint from here, and then do same at the back of dryer where flex hose comes from rear of dryer up into wall then turn on dryer and feel at rear outside vent and see if you can feel the hot air moving more rapidly if so this should resolve your problem
Nov 07, 2010 | Whirlpool LER4634J Electric Dryer
Cloths take way too long to dry. Heat is working in dryer. Timer works, counts down from 60 min, buttheremo drying timer takes way too long.
You will need to check the dryer venting system for a restriction. If there is a restriciton in the venting system the dryer will get hot but the clothes will stay wet due to the moisture never leaves the dryer. First check the air flow at the vent exit located outside. Verify that there is plenty of airflow. Make sure the vent screen is not plugged. Then remove the screen and visually inspect for excessive lint. Then go inside and check the moisture vent hose behind the dryer. Verify that the vent hose is not kinked or restricted. Then remove the hose and clear out any excessive lint. Then check the vent opening at the back of the dryer for any excessive lint build-up. There is a vent cleaning kit that you can purchase from any home improvement store that you can use to clean out the venting system also. When you are done airflow should be good and clothes should properly dry.
Jan 22, 2010 | Maytag Dryers
Takes 3 cycles to dry clothes
This is a potentially deadly scenario. If the clothes are warm but just not getting dry, there is a problem with air flow - specifically - the lack thereof. The chance of fire is a real concern.
Make sure the lint baffle / trap is clear. This should be checked / cleared after each drying cycle. Most folks know about this, but I included it just in case this is your first dryer.
If the the baffle / trap looks clear, the exhaust tubing of the dryer is suspect. Many installations consist of the flexible / expandable hose. This hose may have become crushed during the running of the dryer, reducing air flow. Locate the hose and pull the dryer away from the wall to inspect, expand or replace the hose as needed. If an old installation, it is very possible that the hose has become clogged with lint build up over the years. The hose should be replaced in this case.
If at all possible, use aluminum expandable dryer duct. It is less likely to collect lint as quickly as the flex plastic style.
If the clothes are not warm or hot, the heat source (electric heating element or gas flame - depending on type) has a problem. Either of these problems should probably be referred to a pro for proper repair.
Jan 20, 2010 | Kenmore Dryers
My dryer is saying to check filter but the fileter is clean, the vent hose in the back is clear and it is still not drying the clothes. The dryer is putting out heat, but the clothes are still wet after a...
There is a restriction in the dryer venting system. If the moisture is not removed from the dryer thru the moisture vent then the clothes will get hot but not dry. You will need to remove the vent hose at the back of the dryer and look inside the vent pipe and see if it is restricted with lint. You might need to reach up inside the vent with your hand and pull out the lint. Also some of the newer dryers have a fan assisted venting system and if the fan stops working that can cause this issue.
Dec 07, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My dyer will not dry the clothes
First unplug your dryer from the electrical outlet. Next pull your dryer out from the wall. DIsconnect your flex outlet hose from the dryer and make sure it is not stopped up with lint etc. Next check the wall adapter to make sure it is clear of lint etc going to the outside of the house. If both of these are clear look inside the dryer outlet by looking in the tube where the flex hose was connected. You will need a flashligt to do this. If there is anything stopping it up remove it. If your dryer is getting hot but not drying there is probably something keeping the air from going out of the dryer to the outdoors.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Dryer not drying clothes
An easy way to check dryer function is to check the airflow on the outside of your home at the exhaust the vent. While the dryer is running, and hot, put your hand near the outlet. The air coming out should be hot and forceful. If not, there is most likely an obstruction, and the whole airway should be cleaned. Keeping the airway clean and clear can dry clothes faster and save you money.
Another possibility is the blower,(fan) which can become encrusted with lint, preventing it from moving air. This is much less likely, but still a possibility.
Dec 09, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Make sure that the flex hose going out from the dryer is not blocked. You should check it from both the back of the dryer and all the way to wear it vents outside. It could also be the thermostat, which is cheaper to replace than buying a new dryer.
Sep 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Dryer
tech 17 is right are you might have a lint stuck down in the spot were you put the lint screen in see if you have air comeing out back dryer if not thee your problem
Mar 18, 2008 | Kenmore 62602 Electric Dryer
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
123 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
