Question about Adobe Photoshop 7.0 for PC
Can't open setup for ps7 error 105
In my ps7 folder there are a lot of documents and i don't know which one to use to install and make ps7 operable... i clicked on setup (32-bit setup launcher) and it tells me that there's an error, like number 105 and that it can't open the setup because the lang file isn't there.. i don't know, i just need help with it, i want to be able to use ps7! please help!!! and thank you!!!
4 Suggested Answers
SOURCE: Nero Vision Express 3.1.0.25
same problem, did a lot of research, no fix found, problem with nero dropping frames and not recovering. xvid codec not the issue, many people have the same problem with nero vision. bummer :(
Posted on Dec 23, 2007
SOURCE: error 0x80040702 while installing corel draw 11
when i install corel draw 11 it shows a message that
'error number: 0x40080702
description: failed to load dll: MC Setup
setup will now terminate'
please help me in installing this software immediately since i have to do an urgent work on it.
Thanks
Posted on Feb 18, 2009
Amit Verma
  • 102 Answers
SOURCE: i have a problem during installation of
Copy the source files from the install CD to the local hard disk drive.
Run the setup.exe file from the local hard disk drive.
Posted on Aug 29, 2009
Konica Minolta bizhubc552 error c8102
Here is the error code definition: C8102 Turn around pressure welding alienation trouble
•During a pressure motion being performed, the reverse roller sensor (PS7) output does not change from H to L. •During a retraction motion being performed, the reverse roller sensor (PS7) output does not change from L to H. Further research yields this possible fix, since this model is in the same family as yours: http://www.copytechnet.com/forums/konica-minolta/89213-konica-minolta-bizhub-452-error-code-c-8102-a.html
Apr 06, 2015 | Konica Minolta Office Equipment & Supplies
Tray App msi repair
When you get the error for missing trayapp.Download full feature software and drivers from hp.com. After extracting the downloaded file. Go to your my document's folder. Click tools, go to folder options and make sure to enable "show hidden folders". On the missing trayapp error message, click browse, go to my computer, go to disk drive C:, go to user and document settings, open the folder that has your login name, look for application data > local > temp > open a folder named 7z345 or any folder that has 7z for a file name.. open setup > open trayapp > then click trayapp.msi and click open.. a long process but that should solve your missing trayapp problem.. if you need help, i suggest you call hp
Dec 28, 2013 | Acer Aspire 5735 Notebook
I need a conexant audio update
You can click update driver from the device manager. If that don't work click Start/My Computer and look at the folders on your C: Local Drive. A lot of times you might see a folder called SWWetup (Software Setup), look in it and see if the audio driver and application software is in it, if so reinstall it by opening it and clicking on setup. Also you can look for a folder called HP or Hewlett Packardand most times under HP or Hewlett Packard there will be a Driver folder. Look in the driver folder and see if you can see the Audio and run it's setup. If all fails go to google and type "hp support" and look for drivers and downloads. Go the hp's site, key in your model number when asked and the operating system and download and install the audio driver.
Mar 18, 2012 | HP Pavilion dv6000z Notebook
I don't have a vlc player in my laptop
Hello there!
Here is download link - http://www.videolan.org/vlc/
When you download it, run setup, and follow instructions.
Good luck, rate my solution
Aug 13, 2011 | Computers & Internet
I deleted my Microsoft Office Activation Wizard
try this :
1. Quit all running programs.
2. Download and install the Windows Installer Cleanup Utility.
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
3. After you have installed the Windows Installer CleanUp Utility, click
Start>All Programs>Windows Install Clean Up.
4. Highlight Microsoft Office 2007 entry in the list and then click
Remove. Click OK and wait for the process to end. If any other stand alone
Office applications (such as Visio and Project) appear on the list, please
also remove them. Then, click Exit to close the Windows Installer Cleanup
utility.
5. Click Start>Run, type "regedit" (without the quotation marks) in the
Open box and press Enter.
6. Locate the registry keys below and click Delete from the Edit menu.
Click OK on the following warning dialog box.
Note: Please go to File>Export and backup all the registry first.
HKEY_CURRENT_USER\Software\Microsoft\Office
HKEY_LOCAL_MACHINE\Software\Microsoft\Office
Quit Registry Editor.
7. Delete or rename the following folders or files if they exist:
C:\Program Files\Microsoft Office
C:\Program Files\Common Files\Microsoft Shared\OFFICE12
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Excel
Data\Microsoft\Office
Data\Microsoft\Outlook
Data\Microsoft\Publisher
Data\Microsoft\Templates\Normal.dot
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Word
C:\Documents and Settings\All Users\Application Data\Microsoft\Office
C:\Program Files\OfficeUpdate12
8. Click Start>Run, type "%Temp%" (without the quotation marks) in the
Open box and press Enter. Delete all the files and folders within it. If
there are some files which cannot be deleted, just leave them alone and
this will not affect the result.
9. Empty the Recycle Bin.
10. To remove Mapi, search for and rename the following folders/files if
they exist:
C:\Windows\system32\mapi32.dll
C:\Windows\system32\mapisvc.inf
C:\Program Files\Common Files\System\Msmapi
C:\Program Files\Common Files\System\Mapi
11. Restart your computer and install Office 2007 again.
May 12, 2011 | Computers & Internet
I restored factory settings on my Acer Aspire 1640Z and lost a lot of word documents. I've used Recuva to get them back but when I try to open them, Acer eData Security Management says Error Code 1000-0...
Can you confirm you have Word installed?
Which version of Windows are you running?
I would try right-clicking the Word document and choosing "Open With" then choose Word.
Let me know what happens.
Aug 17, 2010 | Acer Computers & Internet
I have windows 7. When i try to play Nancy Drew: Danger by design a box pops up requesting i insert disc 1. There is only one disc! It seems to work ok on windows xp. Ca you suggest anything to make it...
From the Nancy Drew web site:
Windows Vista/7 Support Installing older games (#1-13) with Windows Vista/7.
While our older games are not completely Windows Vista/7 compliant (notably games #1-13), there is a workaround which has been successful for most players. Please take the following steps to manually install.
If you had previously installed, uninstall the game and then delete all remaining game file folders from your computer, including emptying them out of your Recycle Bin. These files may be in one of the following locations:
C:\Nancy Drew\
C:\Program Files\Nancy Drew\
In your Documents folder: C:\Users\Username\Documents\
Once this is done, make sure you're logged on as an Administrator for your computer and manually install by taking the following steps:
1. Go to your "Documents" folder and create a new folder. Rename the folder with the title of the game.
2. Insert game Disk 1 in your disk drive and open "Computer" from the "Start" menu.
3. Double-click on your CD-Rom/DVD drive, look for a Setup or Setup Launcher Installshield file. Double-click this file to start the installation process.
4. When install asks what directory you want your game to install to, click "Browse".
5. Navigate to the game folder you created by selecting "C:" drive, then "Users" (or User name), then "Documents", then select the game folder.
6. Continue forward with the installation process, when asked if you want to install DirectX, check "No, I will install myself".
7. Upon completion, uncheck the "Play Now" box, click finish and exit setup.
For game titles #1-5, follow these three additional steps:
1. Right-click the game icon that is now on your desktop, select "Properties".
2. Under "Properties", click on the "Compatibility" tab.
3. Check the "Run in Compatibility Mode" box and then select "Windows 98/Me" from the drop-down menu.
You should now be able to open and play the game. If you installed an older version of DirectX with the game, please go to Microsoft's Download Center to download and install the latest version of DirectX for your version of Windows.
Aug 03, 2010 | Computers & Internet
Scan document to text
In order to scan to text or pdf, we need to install OCR.
Please follow the below steps to install OCR.
Please open the link and click on download only.
Once we click on download only, we will get an option to save.
Please save it on the desktop and then run.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=oj-72836-2&cc=us&lc=en&dlc=en
.You will get an eror message that says "This update does not support any of the HP device drivers that you have on your PC. You do not need this software update
Please do not close that window.
Now, please open the temp folder by performing the steps given below.
: Press and hold the windows icon button ( between the ctrl and alt buttons on the keyboard ) and then press the R button.
: Run window opens up.
Type %temp% in the box and press enter.
I would request you to perform the steps to open the run window and type %temp% in the box and press enter.
The temp folder opens up, once that is done.
Please open all the 7z folders and locate the OCR_webpack folder
: Plaese copy the same folder ocr_web_pack and paste it on the desktop.
Close all the windows.
Please click on OK or cancel the error message.
Now, open the OCR_web_pack folder that you have pasted on the desktop.
Double click on the .exe file found in the OCR_web_pack folder.
This should start installting the OCR software in the computer.
You will get the options, Help (folder), Licensing(folder), Setup(folder), Autorun, hpqbpl1.dat, hpzsetup, setup.
: Open the setup folder.
: You would find the OCR setup.exe file, or set up foler or set up file, double click on the same to start installing the same.
Once the installation is complete, we will be able to scan to text.
May 10, 2010 | Office Equipment & Supplies
Problem with setup
just extract the folder and then try to install it again
Oct 18, 2009 | Microsoft Windows XP Home Edition
Adobe Photoshop 7.0 for PC Logo
97 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
