Tape stuck hi -i have an "ancient" philips magnavox vcr....this is what it says on the front: "vcr plus+"  and  "energy star" (but the "star" is a star-symbol"oh, and there's a sticker on the back w/ the number "U239"it's worked great for years (and years).  but today when i hit REW on the remote, the vcr sorta "froze"...it sounded as though it was trying to rewind, but was being prevented from doing so.  then it shut off & a "2" started flashing,i took the top off, but the tape is still looped bet seems to be "trapped" (and very securely, i might add!).i don't know what the h*** i'm doing.help!
Your takeup spool isn't moving.  Before tearing into it further try putting the cover back on the deck and power cycling it.  Hit REW and then try ejecting the tape.  If this works, you'll get the tape back but it's likely the deck is dying.
If not, you need to be very careful to get the tape out:  You may be able to turn the wheel that moves the tape basket to gently ease it out;  otherwise, there are screws on the top of the tape basket.  Remove them and gently lift the tape out while carefully unthreading the tape from the tape guides around the head.  There'll be two feet of exposed tape--pretend it's glass, it's delicate!
Now the tape is out and you need to thread it back in the cassette.  This needs patience, but here goes:
On the front of the cassette, there's a door to protect the tape.  Feel the right hand side of the cassette for a small button;  hold it down to open the door and keep it open
With the other hand (or with three hands! :) ) put your hand under the right-hand tape reel under the cassette.  Carefully turn it clockwise.  It will make clicking noises, but it should ease the tape back into the shell.
Beyond that, the cause of the original malfunction will be a bad reel motor, which is probably not fixable, or a bad belt, which you may be able to locate through mcminone.com.  You'll have to unscrew the bottom cover to investigate further.
Posted on Oct 22, 2007
Tape is stuck, can't remove it
I remove a stuck tape from a VCR by taking off the outside cover. (My unit was held together by 5 screws.) This allowed me to access the tape and check where it was locked. I had to loosen a twisted tape from the mechanism and then I could eject it. (Note: I unplugged the deck before removing the cover.)
I hope this helps.
(I've been fortunate; I've only had to do this on VCR units (not VCR/DVD) that were out of warranty. If your MWR20V6 is still in warranty, you may not want to open the case at home.)
Dec 17, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have a Magnavox MWR20V6 - have a few things going on, one the power shutting off automatically when i put the vcr on timer and therefore does not record, and 2 vhs tapes that are almost new, gets stuck
Junk it. It's identical to Funai WV20V6. I can't remember exactly what is causing the shutdown. But, I do remember that it says it can't be fixed. Read other posts here at Fixya.
"Funai wv20v6 dvd/vcr player recorder"
Mar 17, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
Vcr wont work
Reset the VCR by unplugging/replugging, and then run a vhs cleaner.
May 20, 2008 | Philips Magnavox 20MC4304 20 in....
Philips Magnavox DV200MW8
The tape player section has some safety sensors inside that will shutdown the system when there is a problem. The most common cause of this is either a bad belt or "idler". If the tape is not moving or the take up side is not moving, this will happen. This is a simple repair for any shop and should runfrom $5-$25 for parts (belt - idler) plus the local labor rate.
Dan
Apr 09, 2008 | Philips Magnavox 20MC4304 20 in....
Televison & Video Logo
280 people viewed this question
Top Televison & Video Experts
