Question about Watches
Display only displaying parts of the digits
I have a problem with my watch. It has been like this for quite some time now. Only parts of the digits will display. is my display ruined or is it just bad connection.?
    Problem Solver:
  • 6 Answers
It could be the battery is dieing or your watch is finally giving up. Go to a local retail store to test the battery out, if good then yes your watch has said good-bye.
Posted on May 26, 2009
I can't get the analog time on kennth Cole kc9110 watch after changing battery the digital part in running fine please help thank you
With this type of dual display watch, the two 'mechanisms' are often independant with their own batteries. It's quite possible that the battery for the analogue display has been missed - often they are underneath the battery for the digital display with an insulating cover to isolate the batteries from each other. Sometimes it's even necessary to remove the digital module to get to the analogue module. Obviously, you would need some experience of dismantling watches (and to be very careful) to sort this out. If you don't feel confident, and you value the watch, take it to a professional.
Jul 11, 2015 | Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    Set time
    Hi ajandmjm,
    Please follow the steps below to set the time of your Armitron Digital Sport #40/8125BLK Watch.
    1. Press the MODE button once. This will put you in the timer.
    2. Press and hold down the MODE button. This will put you in the alarm set display.
    3. Press the MODE button once more and it will put you in the time set display.
    4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
    Hope it helps.
    Thank you for using FixYa.
    Apr 26, 2011 | Armitron 40/8125BLK Digital Sport Watch
    Set the time on a Armitron WR330 40/8125 All-Sport watch
    Hi jerryurq51,
    Please follow these steps to set the time of your Armitron Digital Sport #40/8125BLK Watch.
    Hope it helps.
    Apr 22, 2011 | Armitron 40/8125BLK Digital Sport Watch
    The digital display on my timex epedition watch is frozen... nothing I do changes this, holiding down any of the buttons does nothing
    You have to check if the digital part has separate battery. It is quite common to have two batteries in one watch - one for each movement. If this is the case, replace battery. If there is only one battery for the whole watch, you will need watchmakers help to rectify the fault.
    Feb 27, 2011 | Watches
    Hands do not show same time as digital display. the hands are two hours and several seconds behind the digital display. the digital display is correct. when I press the A and B buttons simultaneously...
    I have a Casio which had a similar problem and had to resort to reading he instructions to align the times!
    I presume that instructions for your watch are not to hand but you can get instructions from the Citizen web site.
    Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
    Fill in the information required from the back of your watch and then click on "get setting instructions"
    Mar 20, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
    Digital/analog watch... analog part doesn't run
    A lot of times they hide a second battery for the analog display under the larger battery used to run the digital display. Also, the 2025 may not have a full charge.
    Oct 17, 2009 | Watches
    I,m in Uk, my watch digital display is correct but not hand displ
    you have to go throught the watch menu like your going to change the time. but there is one for the analog when you find it change the time with the start and stop button just like the dig display. you have to hold the button down as the hands scroll.
    Jul 11, 2009 | Nixon Insider NIX0033 Wrist Watch
    The digital time is working, however the analog do not work,¿it is a battery problem? Thanks
    You have to check if your watch has two batteries. It is quite common for two-display watches to have two batteries - one for each movement.
    If there is only one battery, then there is some fault in analog movement and you need to look for watchmakers help.
    Rate me, please.
    Jul 09, 2009 | Columbia Sportswear All Sport Digital...
    I have a Rado DiaStar watch (with digital display), and the hands are out of synch with the digital display. Is there a way of adjusting the hands independently of the display? or must it be sent back to...
    Hears how i do my watch, i have the same watch as you.Just make sure nothing is displayed on the clock face by turning the winder, ie NO digital time, NO daul time, NO alarm, NO stop watch etc, Pull out the winder(crown) and adjust the hands to the time you require by spinning the winder.(Gentley for mins and fast for hours) The digital clock will display wilst doing this, but not change the time.handy if you want to sync both clocks.Push the winder back in at the time to sync and the digital display will go out, then spin the winder again if you want to display the digital features. I hope this helps, please post if it does, Maurice Chevalier- Herts
    Nov 01, 2008 | Rado Diastar Anatom Jubile watch
    Watches Logo
    47 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
