My lervia kh4000 don't fill the empty spool, I press the pedal but the pin don't rotate. (I've pulled out the right handle)
The bobbin winder has a small rubber tyre...probably damaged or broken and needs replacing
it is at the base of the pin and you will not be able to split the casing without damaging it
Looks like this when removed http://drdanessmh.com/sitebuilder/images...
SOURCE: How do I pull up the spool pin?
from the questions I read, this has happened to alot of people.
normally the spool pin should be easy to pull up with 2 fingers, if it's not then most likely there could be something wrong, you can try to use a pair of pliers to pull the spool pin up,, but if it's come loose or broke then it will have to be replaced. and some sewing machine are not mint to be opened by anyone except a factory trained technican.
thanks! to replace that I have to open up the machine? or it's visible?
